Buying an xcharger some questions
You can always upgrade later to the Xtreme. Just need to get the new pulley and the lower manifold. Pull the blower off, pull off the old lower manifold and put the new one in, put the blower back on - then mount the rest of the intercooler components and you are done.
You don't have to order the hi-po plus to do the upgrade. The upgrade will replace everything you need.
I have an x charger with 30k miles and the motor 72k. Engine had 42 when I've installed it. Oil change at every 3k with royal purple and spark plugs at 10k after the supercharger has been installed. Will include the PCM, tuner and 2 custom tunes. I haven't decided to sell it separately from the car yet. I'm just giving a thought as my plan was to find a donor but no luck so far.
