fitting gt style grill & fog lamps to pony ed v6
http://www.ebay.com/itm/HARNESS-H10-...171ae0&vxp=mtr
Yep, a butter knife from behind does wonders to the clips.
Use the proper size screws to mount the fogs into the new
grill or the mounting bosses will split leaving you with loose fogs.
I found out the hard way...
The one I ordered had everything put together and ready for install except the wiring harness. I pulled the fog lamps out and replaced them with a set of factory lights. The ones that came in the grille were very cheaply made and would barely adjust, so I pulled the set out of the GT grille I had laying around and used them. Quite a bit better and the adjustments were easier and firmer than with what came with it. Other than that, it was quick plug and play and add my harness I didn't have originally.
Mine didnt come with Fog lights so I used some GT fogs out of a GT grill.
The OEM screws that secured the GT fogs in the GT grill
were to large for the aftermarket grill I bought to accept them.
So I procured some stainless steel screws of the proper size
to avoid splitting the plastic mounting bosses.
