Clutch pedal assembly broke - advice?
That sounds like a viable option. I bought the replcement billet part but haven't installed it yet. There isn't a lot of room. I'm not sure if the plastic part is pressed on. I don't think its threaded. Let me know how the install goes.
It is pressed on, with glue. You could probably break it apart with pliers. I highly suggest doing it now and replacing it with the metal part. Because **** replacing the master clutch cylinder.
I did the install yesterday. The original piece is pressed on a serrated shaft. It is made from Delrin plastic and no way pliers will break it. Very tough material. I had to use a dremel to cut it off. The billet replacement part is top quality. If you are one that is OCD replace it. I do believe the original part will wear over time.
Thank you dusman59 and blue_steel
Was your replacement part polished aluminum or black treated aluminum
and was it the the part from backwoods_diesel
https://www.ebay.com/itm/2005-2010-M...53.m2749.l2649
