Dual GT takeoffs installed :)
Got my dual GT takeoff muffers installed today, thanks to afixer for the helpful info.
Sounds good...used the same setup as afixer did in his post (Magnaflow X-pipe, factory pipe driver's side, clamped on the rear of X-pipe).
Glad to have that chore done. It is a bit nerver wrecking to cut/Dremel the bumper But a sharp blade in the box cutter and drum file on the Dremel made the task pretty easy.
[IMG]local://upfiles/19206/B004338EC2FD4988B1DFA514ADF92483.jpg[/IMG]
RE: Dual GT takeoffs installed :)
ORIGINAL: SpdSurfn
That looks great! I can see how that would be scary to cut your bumper.
Where did you get the X-Pipe?
Worked out well...
