Off the Road ... Cooling System F*CKED
Old 03-09-2018, 08:04 AM
sexonlegs
sexonlegs's Avatar
Question Off the Road ... Cooling System F*CKED
Hi guys,
I'm at a loss. I can't get my cooling fan to come on. I've replaced the fan assembly (including the resistor), relays 25 and 28, fuse 3, fuse 40, swapped the thermostat and ECT sensor, all to no avail. I also dissasembled the fuse box and had a cursory look. Nothing seemed burnt below the surface; HOWEVER, the socket fuse 40 goes into is melted. There's very little contact left for the fuse. I'm thinking this might be the culprit? The previous fan's positive wire was damaged, and the high speed fan relay was toasted.
The issue began when my cooling fan would only come on when the A/C was on. My A/C currenty isn't charged, so I can't test it that way.
I'm an absolute n00b when it comes to electrical stuff, so I'm hoping someone can help me out.
I was thinking of temporarily wiring in a Hayden 3652 thermostatic fan control. Where could I locate a 12v ignition switched source on an 07 V6?
Thanks, guys.
sexonlegs is offline
camster44
05-26-2010 07:30 AM
huey_33
Archive - Trades & Freebies
10-07-2009 01:35 PM
mastermic
04-28-2009 07:33 PM
aode08
07-31-2008 06:04 PM
Quick Reply: Off the Road ... Cooling System F*CKED
