2013 3.7 rear end sliding
Old 05-26-2019, 01:41 PM
David Guerrero
David Guerrero's Avatar
Default 2013 3.7 rear end sliding
About a month ago I started to notice that my mustang would swerve a little whenever I would shift, let go of the accelerator or press on the accelerator. At first I thought it was nothing but it’s only getting worse now. It literally feels like the car is sliding like when you do a pull without traction control turned on but driving normal.. last night i did a little 2-3 gear pull(about 70% throttle) and when I let go of the gas the car almost drifted and the traction control light came on, on a straight road. If anyone knows anything I need help ASAP.
David Guerrero is offline
Old 05-26-2019, 04:08 PM
GT Nate
GT Nate's Avatar
your trackbar set up correctly in the rear to keep the differential centered?
GT Nate is offline
Old 05-27-2019, 01:54 AM
JJHoover
JJHoover's Avatar
check your LCA's
JJHoover is offline
Old 05-27-2019, 03:29 AM
Derf00
Gentleman's Relish
Derf00's Avatar
Tire wear or tire age.
What at kind of tires you have and how old are they? I’ve found that most tires will begin to gradually lose their capabilities at about the halfway mark of their tread and onward or when they get weather worn. Here in AZ, tires tend to only last about 3 or 4 summers before the heat affects the compounds and traction starts to become a factor. Regardless, tires should be replaced about 6 or 7 years in due to dry rot. Dry rot causes tires to harden and crack.
Summer tires exposed to feezing temps also can be adversely affected.
Derf00 is offline
Old 05-27-2019, 06:24 AM
David Young
David Young's Avatar
My factory all season tires were dangerous with just 15,000 miles on them. Had to be careful even on dry roads, replaced them at 19,000 miles. Problem fixed
David Young is offline
Old 05-28-2019, 06:47 PM
David Guerrero
Have not checked but definitely will after seeing this!
Old 05-28-2019, 06:48 PM
David Guerrero
I doubt it’s my tires, they only have like 4K on them or less they’re brand new.
Old 05-29-2019, 01:26 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Brand new as in recently purchased or less than 3 years old? Then it's not the tires if it just started.
Derf00 is offline
yeet
09-11-2018 01:40 PM
Old_Smokey
03-07-2007 06:09 PM
fredberry
01-13-2007 12:39 AM
dan
04-29-2005 01:23 PM
DanHS
04-19-2004 10:26 PM
Quick Reply: 2013 3.7 rear end sliding
