07 Mustang v6 convertible Ground locations 6 dashes for odometer. No start!
Old 07-09-2019, 09:07 AM
jlattan75
jlattan75's Avatar
Default 07 Mustang v6 convertible Ground locations 6 dashes for odometer. No start!
Does anybody know or have a post where the factory grounds locations are in the car? My odometer shows correct mileage for a second then shows 6 dashes and won't start. I hear that is probably a ground issue. Any ideas?
jlattan75 is offline
Old 07-09-2019, 04:00 PM
jlattan75
jlattan75's Avatar
Ok problem solved. I pulled the power distribution box to check visually and meter all fuses. My thoughts were that there's no problem in double checking. All fuses passed. I then moved onto relays to complete the process. I found a failure at 20 relay which is for the pcm. Rust. G damit. So, odometer going from correct to 6 dashes means pcm miscommunications.
Old 08-15-2019, 05:47 PM
areebashar.23
areebashar.23's Avatar
Darn (but yay!) you figured it out. I had the same issue different solution. Got real excited ahah.
areebashar.23 is offline
jlattan75
Convertible Tech
07-09-2019 04:00 PM
Dacosta
06-17-2017 04:40 PM
Hikari_NOS
02-15-2014 10:07 PM
defiance777
09-02-2011 03:47 PM
drob1389
12-01-2010 10:43 AM
Quick Reply: 07 Mustang v6 convertible Ground locations 6 dashes for odometer. No start!
