I've had it
I've had it
Well, my astra hammond rear window louver flew off while I was driving! It had rained a night before in Maryland, and I'll be damned if the thing didn't fly right off. I've had it with 3M products, because they're too unpredictable. Now I have $200 down the drain, and a cracked louver to prove it. My Rousch quarter louvers had the same problem, so I just took them off. The aftermarket wheels don't stop shaking as well, anyone have this problem with aftermarket wheels? The rings I have don't do jack to keep them from causing my steering wheel to shake. Bad, bad, and more bad!![:@]
RE: I've had it
ORIGINAL: a42mustang
That should address that wheel shake. Of course make sure your all of your tires are wearing evenly, wheels are torqued, and the tires are all the same pressure.
RE: I've had it
thanks for the info, I feel a bit of shaking in my steering wheel, and I have 20's on my car. They are a bit banged up, (hit a few curbs). I figured I needed to have them balanced again. When I take it in for rotation and re-balancing, I will remove the washers (if they are still on there).
RE: I've had it
ya know, it was a dealer add when the car was on the showroom floor, so I dont know. I didnt get to choose them, I bought the car because I liked the color and options. Personally I wouldnt have chosen the wheels, I think they are a bit much. But I like them better than the stock ones.
RE: I've had it
RE: I've had it
ORIGINAL: ford4v429
interesting...I woulda thought that 3M VHB tape would not come off...I still dont know If Id trust it to hold on a plastic piece that will regularly see >100mph windspeeds, but still, thats pretty strong stuff. Just curious, what do they recommend cleaning the glass with before install? often expected would need acetone or laquer thinner to remove any silicones that may have gotten on the glass when waxing- then wondered if anyones damaged paint when cleaning the glass off...when it came off did the tape come off clean or did the foamlike center separate? I see the big rear window(not side) louvers also use tape mounts, think I like the old 69/70 hinges better...
