first oil change
Old 11-30-2005, 10:26 AM
Hambone
Hambone's Avatar
Default RE: first oil change
ORIGINAL: wmscottmc
I've also heard from friends that synthetic is the way to go, but Im not sure they know any more about it than I do. Does anybody else have an opinion on regular vs. synthetic oil for the Mustang? Does Ford have a recomendation, or is anything mentioned in the manual? I wont spend the extra $ if its no better than regular oil, or especially if Ford says not to use it.
Thanks.
Yes, the manual tells you to use Motorcraft Synthetic Blend (weight depends on V6 vs. V8). Read it [8D] You can buy it at WallyWorld.
I had mine changed at 1800 miles to Mobile 1 (fully synthetic). I'll change it about every 3000-4000 miles with Mobile 1 from now on.
Hambone is offline
Old 12-01-2005, 05:53 PM
cman332001
cman332001's Avatar
syn 5w30 for V6 not 5w20 as mentioned by an earlier poster......This info can be found in the manual
cman332001 is offline
Old 12-02-2005, 10:23 AM
Puerto Rico 4.6
Puerto Rico 4.6's Avatar
Mobil 1 10W 30 is what i have always used on my cars, every 3000 miles.
Puerto Rico 4.6 is offline
Old 12-02-2005, 11:09 AM
Hopi
Hopi's Avatar
Personally.....Whether I have synthetic in my 05 or 10w30 in my 73, I never let them go over 2500 miles between oil changes. But on my 73 ,I change it as soon as the oil starts changing color.
Hopi is offline
Old 12-02-2005, 11:15 AM
Torch_Vert
Torch_Vert's Avatar
ORIGINAL: Hopi
Well, technically the oil "starts' changing color as soon as you turn the key after a change. That could get mighty expensive
Torch_Vert is offline
2007StangV6
01-28-2016 06:09 PM
TfcCDR
09-14-2015 12:08 PM
MusicCity615
09-12-2015 07:05 AM
kevsgt
09-09-2015 06:20 AM
Quick Reply: first oil change
