X Charger Mustang 4.0 Picture
The X-Charger should be out in about 60 days and here is a pic for those interested to see it, I have no other info than the pic and it should be out Feb, 06
Also for people with 2006 4.0 from what I read Ford made changes to the 2006 4.0 see below .
The 4.0-liter SOHC V-6 engine received significant improvements for the 2006 model year as well as new engine calibrations and a new camshaft.
T
T
RE: X Charger Mustang 4.0 Picture
ORIGINAL: TJ
T
T
Cool! Do you have a link to the 2006 V6 engine changes? Are you talking about the changes to the 4.0L in the explorer, are the changes the same to the stang?
Hey did you ever run your car at the track that weekend?
I just found out about when the X-charger will be coming out thought I would post it , I will look at all of them and then decide on what to go with.
I am done and tired of researching the strength of this 4.0, I am just going to go with a charger I think this engine can handle it in moderation haven't decided which charger yet. If it does blow I will either 1st pull the charger off put it back to stock and try under warr per repair if not I will rebuild it to stock spec and trade it in on a 2007 GT, I also won't be doing any serious track racing not looking to run 11's or 12's (or serious street racing ) maybe a time or two at the track after I get it setup to see what it turns and will be nice if I need a little power for the street for any reason its nice to know I have it on tap and it should run pretty good for a little 6 .
What kind of gains can you get from this?
ORIGINAL: TJ
Phillip if your talking just about this charger they didn't give me any info on that but a good guess would be about would be about 40% hp increase on this charger.
RedAlertlb
Nah the original x charger for the explorer was like 75hp, and i read on the forums a while back that this is sapposed to put out alot more. So hopefully the post i read a while back is right....
Also seems no intercooler on the Explorer charger, will this one have an intercooler(for increased HP) air or water?
What other info do you have on this charger?
Thanks
They e-mailed me but very little info and no HP rating.
here is the post that i read a while ago about it.....
https://mustangforums.com/fb.asp?m=7...orer%2Cexpress
