seat belt dinger
RE: seat belt dinger
look in the manual dont know what page but it will have a way to disable the warning bell you have to go through a sequence on key on dont start and then buckel and unbuckel seat belt and you have to do it for driver and passenger
ORIGINAL: prozac
Anyone else hate this, You cant even take it off in a parking lot without that annoying dinging noise ... is there any way to get rid of it??
Zach
Zach
If there's a way to do it, it should be in there. 99-04 have it in there. It's a pain and might take a couple times to get it right.
One time disable
If at any time the driver/front passenger quickly buckles then unbuckles
the BeltMinder_ feature for that seating position, the BeltMinder_ is
disabled for the current ignition cycle. The BeltMinder_ feature will
re-enable during the same ignition cycle if the occupant buckles and
remains buckled for approximately 30 seconds. Confirmation is not given
for the one time disable.
Deactivating/activating the BeltMinder_ feature
The driver and front passenger BeltMinder_ are
deactivated/activated independently. When deactivating/activating
one seating position, do not buckle the other position as this will
terminate the process.
Read steps 1 - 4 thoroughly before proceeding with the
deactivation/activation programming procedure.
Note: The driver and front passenger BeltMinder_ features must be
disabled/enabled separately. Both cannot be disable/enabled during the
same key cycle.
The driver and front passenger BeltMinder_ features can be
deactivated/activated by performing the following procedure:
Before following the procedure, make sure that:
• The parking brake is set
• The gearshift is in P (Park) (automatic transmission)
• The ignition switch is in the OFF position
• The driver and front passenger safety belts are unbuckled
To reduce the risk of injury, do not deactivate/activate the Belt
Minder feature while driving the vehicle.
1. Turn the ignition switch to the RUN (or ON) position. (DO NOT
START THE ENGINE)
2. Wait until the safety belt warning light turns off. (Approximately
1 minute)
• Step 3 must be completed within 50 seconds after the safety belt
3. For the seating position being disabled, buckle then unbuckle the
safety belt 9 times, ending in the unbuckled state. (Step 3 must be
completed within 50 seconds after the safety belt warning light turns
off.)
• After step 3, the restraint system warning light (airbag light) will be
turned on for three seconds.
4. Within 10 seconds of the light turning on, buckle then unbuckle the
safety belt.
• This will disable the BeltMinder_ feature for that seating position if it
is currently enabled. As confirmation, the restraint system warning
light will flash 4 times per second for 3 seconds.
• This will enable the BeltMinder_ feature for that seating position if it
is currently disabled. As confirmation, the restraint system warning
light will flash 4 times per second for 3 seconds, followed by
3 seconds with the light off, then followed by the restraint system
warning light flashing 4 times per second for 3 seconds again.
same key cycle.
START THE ENGINE)
1 minute)
off.)
safety belt.
GT350 S550 Tech
09-29-2015 03:29 PM
autoedit
09-27-2015 06:37 PM
