under drive pulley for the 05 v6er's
RE: under drive pulley for the 05 v6er's
http://www.v6mustangstuff.com/05Engine.htm
3rd from bottom of page. BamaChips is trying to put together a package that includes the pulley, belt and puller needed to do the job for $299.
ORIGINAL: Jimp
ORIGINAL: scrming
The graph for the pulley that has big bold red letters that say 12HP and 16ft/lbs is actually reversed... If you actually look at the graph it's a 16HP gain at peak and 12ft/lbs... I will be installing and dyno'ing next Thursday (29th)
ORIGINAL: Kriger
whats the install process for that? Bolt on?
2) unbolt radiator overflow tank
3) remove radiator fan
4) Use 18mm (i think 18mm) impact wrench to remove crank bolt
5) Use the supplied bolts with YOUR harmonic balancer puller to remove stock pulley
6) Use supplied bolt to put new pulley half way on, then use stock crank bolt to finish putting the pulley on...
7) put all the other stuff back...
Since I don't have an impact wrench or harmonic balancer puller I'll be letting the "pros' handle the job! LOL!
