ZEX
RE: ZEX
ORIGINAL: MHShockey30
Did you get your kit from unlimitedspeed.com? What was the exact kit you got?
RE: ZEX
ORIGINAL: rygenstormlocke
Thanks man!!! I will let Chris at Excessive know where the TPS is when he installs it.
ORIGINAL: scrming
yes, it's actually the GT kit... it works perfectly on the V6. The only thing is in the installation manual it says the throttle position sensor is on the passenger side of the throttle body but on the V6 the TPS is on the drivers side...
I got the racers kti locally... You can buy everything seperately but it is cheaper to buy the kit...
Is this the kit you have?
ZEX82034
Price $539.88
ZEX 2005 & 2006 Mustang GT Nitrous System #82034 75-175 HP Adjustable A complete wet nitrous system that fits the new Mustang GT perfectly!
Do they acutally have the racers kit, or just single parts sold separately?
ZEX82034
Price $539.88
RE: ZEX
ORIGINAL: scrming
I actually had one guy print my web page out and take it with him to the installer... LOL! Said it came in handy!
ORIGINAL: scrming
ZEX82034
Price $539.88
ZEX82034
Price $539.88
RE: ZEX
Would I need new tunes after having the ZEX installed? I read that custome tunes for it only work with the Predator, and I have X-Cal. Is that true?
RE: ZEX
Would I need to get new tunes from breenspeed.com where I ordered it from? Or could I just re-flash it? Oh and would you get new gears? Im not sure what would be best.
RE: ZEX
No, just might have to change the spark plug timing with your tuner. Anyone can do it. Ask Scrming or Jimp, they know what parameter to change on the spark plug timing.
RE: ZEX
ORIGINAL: scrming
OOOPS! The spark advance while it is a option for the end user to change does not appear to work! Lidio and I verified it last time I was at his shop. That being said, yes, MHS you need to contact breenspeed to have them make you a custom Nitrous tune. For the 75HP shot you need them to put all the timing back to the factory settings. If you are going to run 100HP shot then you need not only the stock timing put back but they also need to pull an additional 2 degrees...
RE: ZEX
My bad!!!! I thought you could do it. Its an option on the tuner, how annoying. Oh well, better to have the pros do it anyway on a major power adder.
