How to wire fog lights?
I have a purchased a set of fog lights for my V6 and have them mounted, but I have no idea how to wire them. Is it possible just to tie into the headlight wiring so they come on when the headlights are turned on? If so, how exactly do I do this (in very simple terms)? I am trying to avoid having to install a switch, relay, etc since I really don't understand any of that. Thanks.
RE: How to wire fog lights?
it is possible, but rather than wiring in the headlight wiring, I would wire into the switch (have seperate wiring/ power source for your fogs) so that you don't overload your headlight wiring/ fuses. I'm not to sure where you can get a wiring diagram for your headlights/ switch but maybe someone on here can help you or maybe even the dealer.
If you don't have to understand wiring etc, you're better off getting a pre-wired harness
http://www.westcoastperformanceparts...mufogliki.html
the one you want is probably going to be the one with the switch (it's a straight swapout) and will take maybe 1/2 hour install
jaiidutch
09-14-2015 10:29 AM
