Mini Cooper S vs. V-6 Stang
RE: Mini Cooper S vs. V-6 Stang
ORIGINAL: hamidlmt
The V6 Mustang also greatly benefits from some sneakers with a bit more grip than the stock BFG's.
ORIGINAL: scrming
Yeah.. that does help.. but the main thing in my opinion is the V6 is way to mushy and the lack of a rear sway bar results in way too much body roll.... I put in a set of H&R lowering springs and that GREATLY improve the mushy and to some extent the body roll... I'm sure a GT takeoff sway bar would make a big difference... however since I'm goingdown the drag strip path, i put the stock springs back in, won't do a rear sway bar and put in some drag shocks in the rear... LOL
ORIGINAL: hamidlmt
ORIGINAL: rygenstormlocke
mmmm, LCA's. I'm wondering if I can resist putting them in before drag season. I was thinking of doing a project of 1/4 mile times without them, and then with them and posting my slips. But the cold war may dictate otherwise.
ORIGINAL: scrming
ORIGINAL: hamidlmt
The reason I had to put them in is the first time I ran the Nitto 450s I got an incredible amount of wheel hop... very very bad! LOL! The LCA fixed it right up..
BMR makes nice stuff... I would look at those...
ORIGINAL: scrming
Well, they can't hurt and is relatively inexpensive... I would just go with the non-adjustable ones.. I've got the adjustable combo ones... got a deal I couldn't pass up... I don't really need the adjustabilty.. and they are incredibly noisey... LOL!
ORIGINAL: scrming
ORIGINAL: hamidlmt
Cool! So you are saying the fixed ones won't be noisey?
Here's the bushing end:
That ends not noisy... however... they will make the car ride a little harsher.. you will feel the bumps in the pavement more.. The reason for that is... take a look at the stock bushing... big slots in the rubber... very mushy... absorbs the bumps... which on the street is good... but on the track it can cause wheel hop... (the stock LCA also will flex).. all this movement causes the tires to load and unload.. which cause the wheel hop... or at least that's how I understand it...
Here the stock bushing:
mungodrums
09-29-2015 09:18 PM
movielover40
09-15-2015 10:37 AM
09-08-2015 06:25 PM
