Front GT bumper queston
RE: Front GT bumper queston
you dont nessicarily need that, all you need is wire. If you hook up your wire with the fogs, you can use your stock light switch and hook it up to your parking lights... and put a new fiuse in your fuse box. If you want them on a seprate switch, you can get a little toggle switch and mount it just about anywhere you want
Get the V6 to GT wiring loom kit here:
http://www.musclecardirect.com/store...roducts_id=741
It comes with everything you need relay, switch, fuse, etc. for around $75. I just put the kit in and everything works great!
The round switch at the right is the one you install to your existing light switch. It comes out looking very professional.
If you get the compete GT bumper I recommend you get a door panel removal tool, very inexpensive but its better then using a screw driver, also you will need GT wheel well covers because the V6 ones will not line up with the GT bumper. If you need any help with the install let me know.
ORIGINAL: quagmire
Wow! thanks that excalty what i was looking for
To Order Call 1-800-570-5554 m-f P.S.T. Ask for Kevin
clevparts@aol.com
Kevin Casey
05stangkc
Parts Manager
Clevenger Ford Lincoln Mercury
ORIGINAL: 05stangkc
Thanks for the Good Words!
I am here at Mustang Forums now also!
kc
I also Reccomend and sell the Street Scenes wiring kit. It is a good product.
kc
ORIGINAL: 05stangkc
kc
kc
I already have a GT grille, I just need the lamps, wires, and switch.
jwog666
12-27-2021 08:09 PM
