Tech Sheets - Alarms/Radios.....
Hey guys, just wanted to give you guys the tech sheets for our
car.
Radio:
Battery LIGHT GREEN/VIOLET
Accesory GRAY/YELLOW
Ground BLACK/ORANGE
LF Speaker (+) ORANGE/LIGHT GREEN
LF Speaker (-) LIGHT BLUE/WHITE
RF Speaker (+) WHITE/LIGHT GREEN
RF Speaker (-) DARK GREEN/ORANGE
LR Speaker (+) GRAY/LIGHT BLUE
LR Speaker (-) TAN/YELLOW
RR Speaker (+) BROWN/PINK
RR Speaker (-) ORANGE/RED
Securtiy and Remote Start:
Wire Color POLARITY LOCATION
Battery GREEN/PURPLE (+) HARNESS IN CENTER OF DRIVERS DASH
Ignition 1 WHITE/YELLOW (+) HARNESS IN CENTER OF DRIVERS DASH
Starter 1 DARK GREEN (+) HARNESS IN CENTER OF DRIVERS DASH
Accessory 1 BLACK/PINK (+) HARNESS IN CENTER OF DRIVERS DASH
All Door Trigger LIGHT GREEN/YELLOW (-) SJB - J6 GREY
Domelight Super USE ALL DOOR TRIGGER
Alarm Disarm LIGHT BLUE/BLACK (-) HARNESS ABOVE GAS PEDAL
Low Crr Pk Lights BLACK/GREEN (-) HARNESS IN CENTER OF DRIVERS DASH
Anti-Theft Type TRANSPONDER
Key Sense LIGHT GREEN/VIOLET (+) HARNESS IN CENTER OF DRIVERS DASH
Tachometer FUEL INJECTOR OR COIL PACK
Speed Sense DARK BLUE/YELLOW (AC) PIN 3 OF THE 50 CONNECTOR (C175E) OF THE PCM
Low Crr. Pk Lights BLACK/GREEN (-) HARNESS IN CENTER OF DRIVERS DASH
Brake Lights LIGHT GREEN (+) BRAKE SWITCH
Horn BLUE (-) HARNESS IN CENTER OF DRIVERS DASH
Power Unlock BLUE/GREEN (-) HARNESS ABOVE GAS PEDAL
PowerLock WHITE/VIOLET (-) HARNESS ABOVE GAS PEDAL
Driver Mtr Unlock YELLOW (REV) HARNESS ABOVE GAS PEDAL
Driver Mtr Lock RED/ORANGE (REV) HARNESS ABOVE GAS PEDAL
Control Modules:
Module 1 SMART JUNCTION BOX(SJB) - LOCATED IN PASSENGER KICK PANEL
Module 2 PCM- POWERTRAIN CONTROL MODULE IS AT THE RIGHT FRONT CORNER OF THE VEHICLE UNDERHOOD.
Sorry it's a little messy..... but maybe someone can use it...
car.
Radio:
Ground BLACK/ORANGE
Control Modules:
RE: Tech Sheets - Alarms/Radios.....
It should work. what kind of alarm? I havent tried it personally yet, but plan
to put remote start in my standard mustang. The module is basically a
box that holds your key because of the chip inside of the key. Where did
you try to get it insatlled? They probably didn't know what they were doing.
ORIGINAL: IamtheChitt
Jimp: can u be a little more specific? do you mean the lights for ur speedometer?
Here is another piece... the scematic for the back of the radio that might help with mods.
http://webpages.charter.net/thewiz/Mustang/AuxAudio.pdf
Right click and save if your browser doesn't automaticly open PDF files.
I DONT have mycolor, and when my headlights are off, my dash has cool white lights, then when I turn the headlights on, they all turn ugly green. Anyone know how I can switch it so that the lights are reveresed or I can just get the cool white the whole time and just get rid of the ugly green altogether? Is there a wire I can switch? Is it one of these listed above??
HRnB
GT350 S550 Tech
12-18-2015 09:35 AM
inyadreems
08-21-2015 09:10 AM
