NEW SUSPENSION..My bad or Leschwab bad?
Recently installed hr springs tokico struts and with MM caster plates and they had to max them out and yet still my camber is -1.6 and -1.3 degrees, toed correctly, and caster remained a bit off. When i asked why so aggressive Mr. Les schwab said that my plates are maxed out that what i get for lowering my car... Did i set these up incorrectly?
Unless you installed them on the wrong side, I don't see any issue.
How are you measuring camber? You are technically within the OE spec for a 2011 Shelby, so I doubt you suffer much at your current settings. Keep an eye on tire wear.
The OE camber for 2011 Mustang is -.75* (+/- .75*)
The OE camber for 2011 Shelby is -1.0* same tolerance
I didn't search up the specs for an '03, but they won't be much different.
KingRando
10-02-2015 08:06 AM
