MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   Wheels & Tires (https://mustangforums.com/forum/wheels-and-tires-75/)
-   -   275's all around? (https://mustangforums.com/forum/wheels-and-tires/229886-275s-all-around.html)
newb2000GT Jan 11, 2007 04:34 PM
275's all around?
I searched on 275's and it seems as though many people run 275's all the way around. I was really wanting to do 315/255 on 10" and 9" wheels respectively. However, I don't like my tire selection at 315 so I was thinking about running 275's all the way around and hope that's enough meat in the rear to handle the horsepower. Staying the same size will also allow me to rotate them too I guess.
How do those with 275's front and rear like the handling and traction of them?
Should I run 17's or 18's?
Is 9" the right size for 275's or do I need 10" wheels?
TIA!
TsmithGT00 Jan 11, 2007 07:33 PM
RE: 275's all around?
I have 275's all around and it feels better then when i had 245's all around. Plus it looks sweet. And i dnt have any clearance problems in the fron. And i have 18'9's for all 4 wheels and they look awesome. And yes 275's will fit on 9 inch wides
newb2000GT Jan 12, 2007 07:22 PM
Is that thing lowered at all? The front wells look too full and the rears not full enough. Maybe if it were a little lower it might look different. I just can't find the tires I want in the size I want. They have 275's in both 17" and 18" though.
hot wheels Jan 12, 2007 08:06 PM
275's all around going to change to 315's in the rear this spring, but for no other reason than looks. the ride now is wonderful follows the ruts in the road a bit but doesn't take a minute to get used to it. 9 in rim is what is recommended for the 275/40 17
[IMG]local://upfiles/18250/7C192CF4F7AC47E6A7D8516362CBFAD3.jpg[/IMG]
ZZmustang Jan 12, 2007 09:29 PM
I put 275/45/18 on the front and 395/35/18 on the back on my daughters car.
The only problem is rotating the tires. You have to take them off the rim and switch sides.
Waste of $30.00 .
get the same size tire rim so you can rotate them.
[IMG]local://upfiles/58274/AD716F821F274A7CA5575B45F5CD925E.jpg[/IMG]
[IMG]local://upfiles/58274/F5066134FEB34EC6B4C2C1297F6E3A2C.jpg[/IMG]
AdderMk2 Jan 13, 2007 12:58 AM
ORIGINAL: ZZmustang
Im pretty sure most of that was a typo
ZZmustang Jan 13, 2007 06:56 AM
I'll take a close up of the tires and numbers when she gets home from school today.
The wife and daughter went out of town, After thinking about it, The 395 is most likely 295 but the rest is what is on the car. 395 was a bit much. I know its something 95 and 3 seems to big, it must be 295, soon as they get back I'll take pictures.
ZZmustang Jan 14, 2007 05:52 PM
Boy was I wrong
Daughters car has the biggest wheels/tires we could put on her car.
Front 245/40/18
Rear 285/35/18
I don't know what the would come out to in a 17
Boy do I feel dumb
AdderMk2 Jan 14, 2007 11:17 PM
ORIGINAL: ZZmustang
Boy do I feel dumb
Dont feel dumb... there are lots of people on this forum that say things that are WAY more stupid... In fact, im not even sure my grammar on that last statement was correct!
But anyway.... atleast you know now
And as for the 275/40/17's all the way around newb2000gt
check these out
http://www.tirerack.com/tires/tires....s&place=11
You will be looking at about $500 worth of high quality rubber...
ZZmustang Jan 15, 2007 12:43 PM
The ZR in the tire size doen't tell the whole story
For instance a BF tire that says 205/45ZR17 just means the tire is good for over 149 mph, It lacks a actual speed rating like 205/45ZR17 88W, the 88 is for the load index, 88 is 1235 lbs and theW is the speed rating W is 168 mph. Although the ZR is a good rule of thumb the actual letter is better.
© 2026 MH Sub I, LLC dba Internet Brands
