Wheel/Tire Size 4-5 lug disc conversion
Old 02-20-2009, 10:11 AM
dadsmustang61
dadsmustang61's Avatar
Default Wheel/Tire Size 4-5 lug disc conversion
I have a 91 GT Convertible and replacing rear drum with disc and 5 lug on front and rear. I am using SN95 front spindle and hub and SN95 rear axles, disc, 5 lug, etc. I am informed that the rear track with increase by 3/4" per side. What is the largest wheel size and widest tire/size I can use? Stagger is OK. Car has been lowered not more than 1" I believe.
I have been told to stay with 17" and not go to 18" Anyone with same changes and can you help?
dadsmustang61 is offline
Old 06-28-2017, 12:11 PM
snakespit
snakespit's Avatar
I am doing the same to my car, would of liked to hear others input.
snakespit is offline
Old 07-07-2017, 06:54 PM
imp
imp's Avatar
Answers to something like this are difficult to get because of the many variables involved. Wheel set-back is one of the main things affecting tire clearance, aside from rolling diameter. Someone who has done it might provide good answers, but OTOH do you want to accept someone's guess, and go ahead to find out too late they won't clear?
One thing you can do is measure the distance you would have available from the axle shaft flange after installation, to suspension and to fender lip. Then a big rim width and tire width can be decided on . imp
imp is offline
Old 07-11-2017, 03:27 PM
64bit
64bit's Avatar
Use S197 wheels, they will fit perfect.
just get appropriately sized tires for the wheels you get
64bit is offline
Old 07-17-2017, 06:55 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
moved to wheels and tires
mjr46 is offline
11-10-2015 11:39 AM
maestro1024
09-21-2015 02:40 PM
uberstang1
09-21-2015 09:04 AM
Demodulates
09-18-2015 11:14 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: Wheel/Tire Size 4-5 lug disc conversion
