Performance Package rims...possible swap from rear to front?
I am a very proud owner of a 2017 GT premium w/Performance pack rims. I understand the rims are different sizes...I know you can go quite a bit wider on front...I'll get to the point. Americanmuscle.com sells a 10" wide version of the rim, instead of buying all 4 rims I wondered if I could move the 19" 275/40s I have in rear to front and install the American muscle 19" 305/35s in rear...the AM will work in rear I'm sure, I'm just curious if the offset on front will be a problem...anyone know if this could happen? I would then have 275s up front and 305s in back. Thoughts?
I'm also giving the original specs of the rims as follows:
Wheel Specs and Dimensions:
Size: 19" x 9" (Front) 19” x 9.5” (Rear)
Lugs: 5-Lug (5 x 114.3mm/5 x 4.5")
Finish: Matte Black
Backspacing: 165.8mm (Front) 179.7mm (Rear)
Offset: +45mm (Front) +52.5mm (Rear)
Finish: Matte Black
