2015-2016 Mustang GT X-Force Exhaust Sound Clip Varex Catback Exhaust Review
AmericanMuscle.com reviews our Varex Catback System to suit 2015-2016 Ford Mustang GT! The X-Force Varex Catback Exhaust will allow you to change the level of loudness through the interior of your Mustang GT. This exhaust will produce a deep and aggressive exhaust note with a minimal amount of rasp.
See it in action in the video below:
Adjustable Sound. By installing a X-Force Varex Catback Exhaust, you can dramatically change the sound of your S550 Mustang's exhaust from a mellow street sound to a rich, throaty race car growl or anywhere between with just a push of a button. The X-Force Varex Catback features electronically adjustable Varex performance mufflers. Close them when driving through a residential area to stay low key. Then open them up to let your coyote howl while cruising down the highway.
How It Works. Varex performance mufflers utilize a sophisticated internal electronic butterfly valve mechanism to direct the exhaust flow within the muffler. In the open position, the valve "uncorks" the exhaust flow allowing it to take the path of least resistance. The muffler then acts more like a straight-through muffler for a rich throaty race style exhaust note. In the closed position, the valve blocks the exhaust flow, forcing it through the chambered paths to produce a classic, mellow street friendly sound. This unique design is perfect for personalizing the power and sound levels of your Mustang to suit your own specific needs.
Stainless Steel Construction. This X-Force Varex Catback Exhaust is manufactured from high quality 3" diameter stainless steel tubing for superior durability and corrosion resistance. The System includes a mid-pipe resonator and features two adjustable chambered mufflers that end with massive 4.0" diameter polished stainless steel tips. The exhaust tips exit in the stock location for impressive muscle car looks and sound.
Direct Bolt-On Installation. Engineered to be a direct upgrade replacement, this Varex Catback will easily bolt up to the factory piping without any modifications required for a straight forward installation. The control module that powers the butterfly valves can be plugged into your Mustang's 12v accessory outlet for easy plug and play operation or permanently hard-wired to a 12v source - the choice is yours.
Application. This X-Force Varex Catback Exhaust is designed as a direct fit bolt-on upgrade for the 2015 to 2016 GT Mustangs equipped with the DOHC Coyote 5.0L V8 engine.
Fitment: 2015 2016
MPN# ES-FM15-VMK-CBS
Now available for purchase at AmericanMuscle.com
