1A Auto Parts From your restoration project to your daily driver 1A Auto Parts carries the right parts for you. We offer high quality aftermarket direct replacement parts for your vehicle.
1986 - 1993 Ford Mustang Water Pump for 5.0L
Old 06-29-2010, 02:27 PM
1ATony
Former Sponsor
1ATony's Avatar
Default 1986 - 1993 Ford Mustang Water Pump for 5.0L
Click here for current prices..1986 - 1993 Ford Mustang Water Pump for 5.0L
This water pump is a new replacement part that has the following specifications.
Specifications
New not remanufactured
Built to strict quality control standards
Your water pump is a major component of your engine cooling system. If the water pump fails, the engine will overheat causing it to shut down. Water pumps have an indicator that tells you when they are going bad. There is a small hole in the water pump right under the shaft in the middle that the pulley bolts to. As the water pump's bearings wear out coolant seeps by them and leaks through this hole. If you notice a few drops of coolant under the front of your engine this is an indicator your pump is failing. If a water pump fails it will cause engine overheating, and possibly further engine damage. If you have noticed little drops of coolant under the front of your vehicle then inspect the bottom of the water pump to see if it is dripping out of the indicator hole. If your water pump is the problem, then this part is for you. Replace your broken or leaking water pump now with this great fitting replacement part.
FREE SHIPPING
1ATony is offline
Old 07-01-2010, 09:39 PM
mote1985gt
mote1985gt's Avatar
what year did the pump run backwards ?
mote1985gt is offline
Diode Dynamics
28
05-26-2022 12:02 PM
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
eastexsteve
3.7L V6 Technical Discussions
12-04-2015 05:41 AM
08-10-2015 01:44 PM
Quick Reply: 1986 - 1993 Ford Mustang Water Pump for 5.0L
