1A Auto Parts From your restoration project to your daily driver 1A Auto Parts carries the right parts for you. We offer high quality aftermarket direct replacement parts for your vehicle.
1996 - 1998 Ford Mustang Intake Manifold for V8 4.6L (8th Vin Digit X)
Old 08-17-2010, 03:02 PM
1ATony
Former Sponsor
1ATony's Avatar
Default 1996 - 1998 Ford Mustang Intake Manifold for V8 4.6L (8th Vin Digit X)
CHECK LINK BELOW FOR CURRENT PRIGING.
Our intake manifolds are some of the highest quality replacements on the market!
This injection molded intake manifold with aluminum crossover is a new, aftermarket replacement part. It is a direct bolt on that is built to strict quality control standards.
The original intake manifold, due to the design, has an abnormal tendency to crack, leading to overheating and in many cases complete engine failure and/or damage to other parts of the car's engine. This new and improved intake manifold is designed to eliminate those problems!
This new upper intake kit has the following specifications:
Square port design
Reinforced aluminum coolant crossover - which means no repeat failure due to corrosion or vibration
Highly engineered reinforced plastic
Intake gaskets molded into the intake manifold
Replaces dealer part numbers: F6SZ 9424 AA,F8AZ 9424 AAA,F8AZ 9424 BAA,F8AZ 9424 BC,F8AZ 9424 CA,F6SZ9424AA,F8AZ9424AAA,F8AZ9424BAA,F8AZ9424BC,F 8AZ9424CA
Kit includes:
Complete improved intake manifold with new aluminum crossover
New thermostat, o-ring, and screws
Bracket for installing alternator
Spacers to install original thermostat housing - making it not necessary to replace the hose and thermostat housing
Installation instructions with torque specifications and tightening sequence
Everything needed to do the job right the 1st time!!
If you are tired of having car problems because of a bad intake manifold, then this part is for you! Replace your broken or damaged one now with this great fitting, alternative.
It is built to strict quality control standards and is a great replacement that has substantial cost savings over a dealer unit.
Backed by manufacturer's limited LIFETIME warranty.
For as long as the original purchaser owns the vehicle, in the event this manifold should fail due to manufacturing defects, we will REPLACE the part free of charge. Warranty is limited to replacement cost only (excludes shipping charges). Failure due to improper installation, or improper use is not covered. Please keep your invoice for proof of this warranty.
BUY THIS PRODUCT HERE
This part replaces:
HOLLANDER #: 329-1514
1ATony is offline
mtgldr
02-03-2024 09:00 PM
Galactic
04-29-2019 02:56 PM
JonnyBlazeGT
11-03-2015 01:10 AM
UPRSharad
09-08-2015 03:46 PM
Calizic
08-28-2015 01:46 PM
Quick Reply: 1996 - 1998 Ford Mustang Intake Manifold for V8 4.6L (8th Vin Digit X)
