Any info or guesses on the combined fuel economy for the 2.3 Ecoboost engine?
#31
I'm pretty happy with the numbers that they released and it's what i expected with the weight and power.
From looking at the V6 auto vs the V6 manual it seems the auto gets better fuel economy. My guess would be the ecoboost auto is going to be Ford's bread and butter, so I'm guessing a 27mpg combined for the 2.3 ecoboost auto?
Thoughts?
Thoughts?
#32
Thoughts?
Thoughts?
#33
#34
Yes, there is a very well defined EPA test cycle to determine the FE label of every car. There is also a modification factor to lower the rating to account for more real world driving since nobody drives as carefully as the test cycle. This is why it is easy to get a better number than published especially on the highway. The modifier is about 20%. So if a vehicle attains 20 MPG in the test then the published number is 16 MPG. The need for this modifier is especially true with the Ecoboost engines as a boosted engine seems to be more sensitive to aggressive driving practices than a non-boosted engine.
Anyway, there is no guess or debate over the label data as it is available for any vehicle here (including information on how the measured data is modified and why):
http://www.fueleconomy.org/feg/Power...ng&srchtyp=ymm
#35
New to the forums. Took del of EB/prem/auto 2 wks ago. Also have a 2011/6/auto. With same driver and roads, I was getting about 22 overall with the 6 and highest with cruise-control on hwy of about 29. With the stock EB (during break-in) I'm getting about 28 combined and 34 on hwy using regular gas.... I should get a little better with premium (and after break-in).. Not a huge difference from the 6, but much better than the 8 of course.
#36
#37
Just for the heck of it, I tried to see what the max gas mileage might be under optimum conditions.... Instead of 75MPH I took a test trip at 60MPH and economized my driving (driving with minimum braking/acceleration and A/C off. The best I could do was about 40MPG, then I just had to put the A/C back on and MPG dropped under 40 (about 38-39). Nice numbers, but realistically, @75 MPH with A/C on and occasional spurts for passing, I've been getting about 34 pretty consistently. With sporty driving on more curvy back-roads, the 2.3T is a blast, but also MPG suffers ....MPG drops to under 30 very quickly, averaging about 26-28. It's all good.
#39
I think it has a lot to do with how fast you are actually driving.
I just got mine delivered last week from Ohio. The person that drove it back used cruise control and was probably 65-70mph.
He got 34.3MPG !
On my last trip running at 75mph I got 31.3MPG
So if you could actually stand driving at 55MPH, the fuel mileage would be amazing !
He got 34.3MPG !
#40
He got 34.3MPG !
He got 34.3MPG !
About 8 months ago I got the Ford Racing tune-up for my 2.3 (390 ft/lb torque, 100 more HP at top end)....well I LOVE IT!!!
However....how does it affect the gas mileage...big concern:
After some testing in "Normal" mode, gas mileage at highway speeds not affected noticeably, that is, still getting in low-to-mid 30's at 70mph. One thing I did notice was that at 75-80mph cruise, gas mileage was still in low 30's...my guess is the higher torque offsets the wind resistance so additional throttle not required. Any ideas on that?
Didn't do much testing above 80mph, but seems mpg still near 30 or so...not bad in my opinion.
In "Sport" mode on a twisty fun road, well no change here .. gets thirsty pretty quickly, but the smooth power is so addicting it's worth it (call it entertainment cost). Nice to have both good mpg as well as pure power on tap when I want it. Highly recommend this setup (by the way, newer 2.3 Mustangs to have this superior tune stock).
