Ecoboost fuel tank smaller, why?
I was at the dealership this morning reading the 2015 brochure and it stated that the ecoboost has a 15.5 gallon tank and of course the v6 and 5.0 have a 16 gallon tank. Anyone know why the ecoboost has a smaller tank?
Interesting. ..do smaller turbo four cylinders need a bigger fuel pump than naturally aspirated six and eight cylinders? I also doubt they would make the gas tank different so if that capacity is not an error then it must be something inside that needs more space.
Actually what if that gas tank was similar to some of their other vehicles instead?
or maybe the exhaust system is different enough (larger or relocated resonators or something) which meant the tank had to shrink a bit to clear it.
the 2.3 is the only one of the three engines which is direct injected. The fuel pump module could be different enough due to having to deliver greater pressure to the HPFP.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
mrappe
09-26-2015 10:16 AM
