2.3L Eco-Boost Tech This section is for technical discussions pertaining specifically to the Eco-Boost variation of the 2015+ Ford Mustang.
OD question
Old 06-13-2015, 10:45 PM
pigdoc
pigdoc's Avatar
Default OD question
I've got the Foundry 18 x 8 inch rims on my 2015 EB Premium. If I were to upgrade to 19" or 20" rims, how much (if any) would the Outside Diameter of the tires be for each different rim? Thanks in advance.
Pigdoc
pigdoc is offline
Old 06-14-2015, 01:39 AM
AK_Kayaker
AK_Kayaker's Avatar
Ok this is easy stuff, first you go to the Mustang brochure,
http://www.ford.com/services/assets/...tang&year=2015
then you find the wheel/tire sizes
235/50/18---------255/40/19--------265/35/20
if you want the info in inches convert dividing the width say 235mm by 25.4(the number of mm in an inch), then multiply the width by the sidewall ratio so 9.252x.50=4.626, then multiply by 2, so 4.626x2=9.252, then add 9.252+18=27.252
But since I know you don't want to do all that.
235/50/18=27.252"
255/40/19=27.032"
265/35/20=27.303"
Of course actual tire size will vary due to manufacturing tolerances.
No more than about a 1/4" difference between any of them, that's why bigger wheels give a harsher ride, less side wall to absorb the road imperfections.
AK_Kayaker is offline
Old 06-14-2015, 07:33 AM
bluebeastsrt
bluebeastsrt's Avatar
Somebody paided attention in math class.
bluebeastsrt is offline
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: OD question
