footwell lights?
#23
I bought the Mustang LED kit from www.venomousstangz.net along with 2 blue LEDs from amazon.com for the maplights. It all came out really nice, only took about 2 hours. I wired the kit into the passenger door fuse box and stuck the control box in the right hand corner of the panel under the steering wheel. The footwell/underseat lights only comes on when I press the on/off switch but I like it that way.
Uploaded with ImageShack.us
#24
I followed this post from another forum and put the green optix LED pods (they look like the football-shaped pods in this auction so they fit the factory cutouts perfectly) where this guy did (the factory location for the ambient lighting). I got a bulk set of individual LED's from off ebay for dirt cheap (CHINA), and drilled a hole in my cup holder, and two holes in the back sides of the center column for the rear footwells. I wired it all to a switch located near the cup holders, and tapped into the 12v outlet in the center column's power and ground so I can turn them on and off at will. The last page has a link to a set of install directions from FORD in PDF format you can view and/or save as well as some pictures of the actual light pods.
#25
Thanks -
