brake re-paint tips
brake re-paint tips
What do you all recommend for touch up paint on the brake calipers?
I have a rattle can Duplicolor in red ready to go.. my brakes look very shady since their first paining back in 08.
They still have a bit of color, but look worn. Can I simply use some scotch brite with some brake cleaner, then spray them?
lite coats, followed by wait time then more thin coats. I was thinking of using a heat gun to quickly dry the process..
any suggestions welcome
I'm not a pro at this but I believe if you plan on painting ontop of the pant you have you have to clean it very well or it will flake off fast. What I would recommend is to go to home depot and buy one of the wire wheels and scuff it a up. Or clean it right to metal if it all flakes off. Then make sure u clean all the dusty flaky paint stuff. Then you can spray them. I used this process on my calipers and they look great
Which brand? I used Dupli-color and now it's crappi-color lol
wash dust off with standard car wash soap then invest in duplicolor caliper paint kit...
painting the color on with a brush is much easier than rattle can, not to mention no masking needed!
also the paint is thicker with the kit and you can brush on multiple coats for protection
Great topic. This was something I was going to post a question about but found this thread instead.
I too am looking to paint my calipers but want to paint the entire caliper a new color...I have a green Bullitt and I bought a set of used RED calipers that would make my car look like Santa Claus' personal ride, so I want to paint black.
I contacted StopTech but they refused to repaint, but I figured there must be a way to do this given how many factory calipers I've seen custom painted.
My calipers are not on the car at he moment and I was wondering if painting requires any disassembly in order to avoid getting paint on internals?
Thanks!
Thanks!
Do not use duplicolor they will just continue to flake over time. Get some lacquer thinner and carefully remove old paint and then buy this kit from G2 it holds up way better than Dupli.
http://www.g2usa.com/product/G2.html
