Dyno Results 06 Kenne Bell
Well here's what I got...
The IAT was over 150* here in Scottsdale, AZ & I know it had a pretty ugly effect on the power, but we did get 10lbs of boost out of it.
Please review & let me know if this is all I am going to see for my $8000 in this heat. Can't wait to see what she runs on a DynoJet in the winter!
Thanks for any ideas on how to beat the heat!
[IMG]local://upfiles/31159/4FBFADC5E848483AB11F5EB96B81C46A.jpg[/IMG]
RE: Dyno Results 06 Kenne Bell
Hey even if it could improve I wish I had those #s at my rear wheels. What is the elevation in scottsdale? I know in east new mexico its like 4400' and its killin me. Can't wait to get out of this hole.
ORIGINAL: MacGyverGTP
Well. I guess I will be the bad guy.
Personally, if it were me and that was all I got out of 10psi, I would be pretty disappointed. Yes....I know it is a Mustang dyno. Yes... I know it is hot in Arizona. But I put down over 440 to the wheels ( Dynojet ) on a 100+ degree day with 8psi.
Your A/F is about a point and a half off of what it should be also.
ORIGINAL: hawgman
I would have thought the KB would put up better numbers than that. Something's amiss.
Was it an auto or manual?
From what I have read, this is about the equivilent to having 403rwhp on a Dynojet, but not sure if that is accurate. Scottsdale Elevation is 1500' MSL & it was about 105* out today.
I am pretty disappointed... And I had to wait 3 months for it.
How do you know the A/F ratio is off? The guys who did the dyno said this looks a little on the safe side, but I would get little power for a lot of risk if I went any leaner. Mind you, this is the canned tune the Kenne Bell came with & I do trust that it is in their best interest to be conservative.
Should I do something? take it to a dynojet & see what it does? wait till winter? drive over to California & see how she acts? Just unsure where to go & what to do.
Would love to find someone out here who is running a KB & compare. With the stock 18" rims & wheels, I can't even break them loose in 2nd gear & just barely in first.
Thanks for any suggestions!
Sean
Sean
Sean
Sean
Yea, a Mustang dyno is going to read around 16% less than a Dynojet. So your guess is pretty accurate. Your A/F should be somewhere around 11.5 and yours at one point was 13 ( too lean ). Now, to me reading a Mustang dyno chart is about like reading a seismograph readout. I can't tell crap from it. So I don't really know where the max A/F readout was at. Maybe someone a little more knowledgeable with Mustang dyno graphs can chime in on that.
As far as taking it to a shop with a Dynojet. I personally wouldn't bother unless they were also tuning it. Your power is way down. To give you an idea, you are making less with 10psi than I did with 4. Now granted the weather conditions probably had something to do with that, but still you are way down. Just for giggles one day I threw a 10lb pulley on mine and made 480. And will probably put one back on in the future. But for the present until I get the cash to make a couple of changes I am going to stick with the 8lb pulley setup.
If you do drive over to California, take it to ST Motorsports in San Bernardino. Let Adam tune the car. You should see quite an improvement.
I have not been on a dyno yet, but the only reason for me would be to verify the A/F ratio. I'm happy with the power (from my "seat of pants" dyno).
I think I remember the stoichiometric (most complete combustion=best gas mileage) ratio was 14:1, but for power it was 12:1. For alcohol, you go to 9 or 10:1. Having a rich ratio is also safer. But we all know that anyhow...
As far as traction, my car has a manual trans and the stock P-zeros. First gear has two possibilities when I'm on it:
- immediately smoke the tires till the shift light/rev limiter hits
- have good traction until the boost comes in, then severe wheel hop and shift light comes on
I'm using the stock KB tune, and I'm not even sure if it is loaded correctly.
Good luck with your car, but I would say that is an altitude/temp thing. I have a lot more power in the dark.
BTW, I have some BMR LCAs and relocation brackets that just came in. I'll see what they do, then get some fat BFGs when these tires are gone.
