SERIOUS LEAKING/ELECTRICAL PROBLEMS WITH 05+ MUSTANGS
#121
RE: SERIOUS LEAKING/ELECTRICAL PROBLEMS WITH 05+ MUSTANGS
ORIGINAL: TinPony
Just found this on another forum:
#122
This is starting to scare me a little bit to now....so far I have had no leaks but HAVE noticed what seem to be wet spots on the passenger side floor. I never really thought twice about it. It's currently pooring rain here in sunny Florida, but first thing tomorow morning i am going to go check it out and rip out that carpet behind the glove box and see if I have the same problems......I hope no though I have a bunch of aftermarket electrical crap for my stereo system up there
Thanks for all the great info though !!!
#123
Wingman75:: www.shelbyautos.com go to the public forum from the main page
#124
ORIGINAL: BHRS
If the problem is a plugged drain, where is it??? If it is easy to get to then it is something to keep an eye on-or if it is in a difficult then add the inspection to your regular service schedule.
I have been reading this thread hoping the problem does not involve the '07's. I am ordering my Vista Blue GT next week.....
Welcome to both worlds partner!
#125
It seems to me trying to enlist the support of Carroll Shelby himself would be a good strategy. I don't think he wants his name associated with a product with an increasingly destructive problem. The more cars they build the worse the problem becomes. Since the electricals are at risk I think that a prospective safety issue is also a possibility. The government agency dealing with safety issues could be employed.
Possibly Ford is letting this ride till the next model change-over. This would not be good for us or those still contemplaiting buying an S197 in one of its derivatives. Its one thing to have a problem and see a fix being applied and quite another for Ford to keep owners in the dark.
I know we have some Ford insiders on MF. How about getting some info on this issue? I just want to know that something is being done about it and that its not going to be covered up and forgotten.
We need a leader(s) to take this further... any volunteers?
#126
Wingman, I work for Ford and have been following this thread regarding the leak. I have a 2006 Mustang GT and I have been one of the lucky ones with no leak. I have been periodically checking the FMCDealer.commessage boards (Ford employees and dealer personnel only) and not a single tech has brought up this issue on the boards. I can tell you that the techs are not shy about bringing up any issue they have to see if other techs have experienced the same thing and how they fixed a particular issue. This tellsme that although the issue seems large on this forum......it may be fairly small in reality. I am willing to compile a list of VINs of those vehicles effected to see if there is some common denominator we're missing here. PM me your VIN if you have had water leak into the passenger footwell which was not caused by your own carelessness (window left open, cut a hole in the car for wiring to aftermarket equip and didn't properly seal that hole, water bottle cap not on tight, etc).
#127
ORIGINAL: bascho
Wingman, I work for Ford and have been following this thread regarding the leak. I have a 2006 Mustang GT and I have been one of the lucky ones with no leak. I have been periodically checking the FMCDealer.com message boards (Ford employees and dealer personnel only) and not a single tech has brought up this issue on the boards. I can tell you that the techs are not shy about bringing up any issue they have to see if other techs have experienced the same thing and how they fixed a particular issue. This tells me that although the issue seems large on this forum......it may be fairly small in reality. I am willing to compile a list of VINs of those vehicles effected to see if there is some common denominator we're missing here. PM me your VIN if you have had water leak into the passenger footwell which was not caused by your own carelessness (window left open, cut a hole in the car for wiring to aftermarket equip and didn't properly seal that hole, water bottle cap not on tight, etc).
ORIGINAL: bascho
ORIGINAL: bascho
As you say the problem could be minor in Fords eyes when looking at the big picture. I did think of that. We are so concerned with our cars here compared with the general public too. Hopefully they will get a handle on this and fix it once and for all.
So bascho, thanks for easing my fears a bit.
#128
>> I think that since I've become a member of MF I'm getting more and more paranoid reading about the problems some are having. I start
>> hearing things that are not there. I feel vibrations and have to ask the passenger for confirmation.
When I first bought my '04 Nissan Titan, I mentioned some of the issuesthat Iheard about on TitanTalk.com to the service writer, even though I was not having those issues. He jokingly referred to the forum as a "whiner board", but from other comments he made it was clearits best to not mentionyou heard about problems on owner forums, as they might think you are imagining those problems.
#129
I guess I am one of the lucky ones, I have had the car for over a year now and haven't had any leak issues and it's been down pouring where I live.It hasen'tstopped rainingfor the past couple of days. I did on the othe hand pull the carpet back and the kick panel and used clear silicone at the top of the floor board body seem do to the fact there was a tiny spot where it didn't get cover/sealed all the way. This was located in the right front corner of the floor board. I also noticed there was a hole on the left side of the fuse block that was threaded for a bolt but there wasn't any thing bolted through it. It had a rusty rim around the threads and I cleaned it up/painted it with touch up paint and put a bolt in it. This may well be a area to check for leaks. I guess if you find a reason to seal something it's better to be safe than sorry.
#130
We've had a few days of hard rain here and I was driving my '06 around in it yesterday. I checked behind the glove box, inside the access door, under the carpets etc. and I can find no trace of dampness. I did not look under the hood. Makes me thing that this problem may be more of a hit-or-miss situation or one that develops over time. Anyone else NOT having this problem like me?
