SERIOUS LEAKING/ELECTRICAL PROBLEMS WITH 05+ MUSTANGS
#411
RE: SERIOUS LEAKING/ELECTRICAL PROBLEMS WITH 05+ MUSTANGS
ORIGINAL: Juntech
Is it confirmed that this fixes the problem? Because if it is, it's simply a matter of replacing the grommet with some kind of mesh. But the TSB calls for seam sealer around the grommet. That just dosen't make sense.
#412
ORIGINAL: Juntech
There are two areas of leak problems,
#1When the drain grommet at the bottom of the cabin air inlet area gets plugged with leaves and the water comes in thru the vents.
#2 The TSB about the leak that is occuring on the
passenger side that allows water to get in the SJB
and causing the electrical problems that requires the
grommets that feed wires thru the firewall and hold the
cowl top clips to be recaulked.
Theproblem is figuring outwhich one you have
and hoping its not both.
#413
Hey there Guys & Gals.........Although i can't provide the link to the TSB re: The Water Leak Issue. I did all the steps myself. I used Seam Sealer. NO LEAKS!!
To do the windshield cowl you have to remove the wiper arms. Use a battery terminal puller. You have to invest a few bucks but it saves you Major Problems and Major Bucks!! My Stang is still under warranty but No Dealer having my Stang several times to try to fix the problem. It took me a total of about 8 hours to follow the TSB. BTW when you do the fender liner removal buy some extra push pins from the dealer prior to the wire grommet sealingin the wheel well. You will break a few. Have Fun!!
#414
Well after 52 days at the dealership my hunk of crap still leaks. Nobody can fix it including Fords FSE. All the TSB have been done.
One cause was NO BODY SEALER put in the floor board seem.
My interior has been out so many times it does not fit correct any more and rattles on smooth roads.
Ford customer has given me nothing but run around and since I live in ILL I have to sue Ford myself becuase of the crappy Lemon laws here.
I recommend to anyone to stay the hell away from these hunks of junk and that they go by the new Challenger.
#415
Just bought a used 2005 w/ a dam water leak, have sealed seemingly everything and the SOB keeps leaking but only when being driven in the rain. How frustrating to buy a car that I've always wanted only to have to go to work on it immediately. Thanks Ford...you suck
#418
#420
I have taken my car in twice now.. first time they replaced the padding because they found mildew on the padding.. HELLO.. how do it get there if there is NO LEAK..?????
so I just took it back AGAIN THIS week.. I even told them.. the smell IS THERE.. keep it for a MONTH .. if you need it that long.. just fix my problem.. two days later I get a call.
" your car is done.. no problem found Sir. "
now I am majorly pi**ed off.. called the BIG GUYS at Ford.. they will fix this problem or I am going to sell the car.. this car only has 4,200 miles on it..!!!!!
(((( ALSO: if you guys with newer cars think you are safe.. well so did I .. but as time went by.. sure enough.. I also ended up with this problem..
we ALL need to call Ford on this.. as this is BS..!!!!! ))))
