Sponsored by:
Sponsored by:
How hard can you push the manual,4.6 3V?
Old 04-24-2013, 03:26 PM
  #21
Lem-06
Lem-06's Avatar
Originally Posted by lol_vtec
Thanks guys. Makes mn feel better about my plans for my baby!
remember that 819 was a hail mary run on race gas and some good tuners behind it on a dyno.
aim for mid 400's for a reliable DD/track car
Lem-06 is offline
Old 04-24-2013, 05:23 PM
  #22
danzcool
danzcool's Avatar
^^^ what he said.
pretty much up to 450 you're good on the 4.6L if you don't go crazy with revs above the redline, anything above 500 is generally considered running on borrowed time.
danzcool is offline
Old 04-24-2013, 08:25 PM
  #23
UPRSharad
Former Sponsor
UPRSharad's Avatar
Originally Posted by danzcool
Yeah, that's my car. It was shut down at 6k rpms every time, which furthers the "RPMs kill" argument. The last # was 819, and that was due to running out of fuel pressure (there were some issues with the fuel pumps and the injectors were only 60LB).
It may never have a 1/4 time, it was built for standing mile trap speed (should see WOT into 6th). Will probably do some road course on reduced boost also.
On the overlap cams, I would think that the fact that the exhaust and intake are open would also limit the positive pressure in the cylinder.
^^'Merica!
UPRSharad is offline
Old 04-25-2013, 11:07 AM
  #24
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Originally Posted by UPRSharad
There's a thread (with video) on S197forum where a shop tried to blow up a stock 3V before installing the customer's built motor. On twin turbos and race fuel, I think they gave up trying to blow it up on the dyno after around 8 or 9 pulls and making something ridiculous like 7-800rwhp. Your mileage may vary, but the point is, it's all in the tune.
link- https://mustangforums.com/forum/2005...-part-1-a.html
great thread above and this thread is old!....
danzcool....yours maybe an exception but you prove that tuning means everything...
http://www.alternativeauto.com/Lidios_Rant.html
good article and my stang made 465RWHP with a safe tune on 93 octane with a max of 19 deg timing, 60# inj, and later added GT500 dual fuel pumps with about 11psi boost. She is still running strong today on the stock block with stock weak powdered rods etc...remember if one thing fails in the whole equation the motor can go boom!
mygt500 is offline
Old 04-25-2013, 02:30 PM
  #25
ZPounds07GT
ZPounds07GT's Avatar
Hello all,
First off I'm new to this forum and just purchased my first Ford Mustang. I've had the car for a few weeks now and have already added intake and exhaust. I have many more plans for my new baby. My question is......What can I get away with, power wise, before I need to build a stronger bottom end? I have a cai new throttle body, long tube headers, x-pipe, and exhaust. I want the frpp intake manifold, hot rod cams, and frpp stage 1 heads. Beyond that I don't know what the stock block can handle. Any pointers would be appreciated. Thanks in advance!
450 to the wheels is the general census for the stock bottom end. Anything higher than that and you're on borrowed time. A simple search should pull this up for you.
ZPounds07GT is offline
Old 04-25-2013, 08:11 PM
  #26
Norm Peterson
Norm Peterson's Avatar
Originally Posted by mighted1987
Anyone can enlight me up on my previous post?
Ford apparently feels that 6200 rpm is a safe enough limit for occasionally encountering it. This is most likely a fatigue limit, where Ford would have a design basis number of rev limit occurrences and engine revolutions per rev limit incident in mind.
The failure mode for the rods is tensile, but the reason that tension is developed in the rod is because the piston is undergoing tremendous negative (downward in the cylinder) acceleration as it passes through TDC. Meaning that although the piston only weighs about one pound, at 6200 rpm (and about 2500 g's) the rod thinks it weighs well over a ton.
Nothing that you do with a tune can improve the mechanical strength of the con rods or improve their fatigue life.
Norm
Norm Peterson is offline
Old 05-02-2013, 02:18 PM
  #27
lol_vtec
lol_vtec's Avatar
Well my plans for the future include a new top end. No boost. My tuner seems to think I can get close to 400 rwhp with the new top end. Think my bottom end will survive with a little track time? ( stock revs adheared to?)
lol_vtec is offline
Old 05-02-2013, 05:04 PM
  #28
danzcool
danzcool's Avatar
at stock revs, no problem at all.
danzcool is offline
Old 05-02-2013, 06:53 PM
  #29
def67
def67's Avatar
What parts are you getting for the top end?
def67 is offline
Old 05-03-2013, 10:24 PM
  #30
def67
def67's Avatar
Bump, does ford or anyone still sell the "top end package". I couldn't find on there site.
def67 is offline
Quick Reply: How hard can you push the manual,4.6 3V?
