Sponsored by:
Sponsored by:
Old 10-22-2015, 06:38 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
Print Wikipost
Does your 2005-2007 Mustang have a water leak?
Old 02-10-2007, 12:30 PM
  #31
2cokeman
2cokeman's Avatar
Default RE: Does your 2005-2007 Mustang have a water leak?
DON'T KNOW, DON'T DRIVE IT IN THE RAIN!
2cokeman is offline
Old 02-10-2007, 01:26 PM
  #32
NyFordTech
NyFordTech's Avatar
Ford Definetly nows about this problem i had a 06 v6 in the shop the other day cust was complaining about battery being dead after a few weeks in garage,called ford tech hotline first thing they wanted me to check was the SJB passenger side for water intrusion. there is a problem with some vehicals leaking water definetly check every few weeks n after rain storm if sjb get wet not good.
NyFordTech is offline
Old 02-10-2007, 01:52 PM
  #33
2cokeman
2cokeman's Avatar
I HAVE HEARD THAT THER 07 STANG SITS ON THE NEW SHELBY FRAME, DOES THIS MEAN 07 MAY NOT BE AFFECTED BY THIS WATER LEAK PROBLEM?? IF YOU LOOK AT THE PASS STRUT TOWER ON THE 07 IT HAS DIFFERENT HOLES THAN THE 05 AND O6, I KNOW BECAUSE I HAD BOTH, ALSO DO WE KNOW WHERE THE WATER IS ACTUALLY COMING IN? WOULD IT COME IN WITH THE CAR WASH UNDER CARRIAGE SPRAY??
2cokeman is offline
Old 02-10-2007, 04:35 PM
  #34
2cokeman
2cokeman's Avatar
Just checked my pass for water, none yet....but I am curious, behind the inspection cover can someone tell me if there is a white foam pad and large diameter hard covers over the wiring?? because i think my 07 is modified for the leak? or is it because the 07 is on the Shelby frame?
Thanks
2cokeman is offline
Old 02-10-2007, 05:03 PM
  #35
wingman75
wingman75's Avatar
I've only driven my '07 in one briefly heavy rain but have washed it many times since Aug, about 4500 miles. I have not seen evidence of a leak. However I have noticed that the passenger side window sometimes fogs up a bit which makes me wonder.
wingman75 is offline
Old 02-10-2007, 05:44 PM
  #36
TPony
TPony's Avatar
ORIGINAL: Daniel60
I knew this girl at work had the same 05 as mine but with red interior and it freaking leaked too.[:@] Now she owns a Lexus.
Bet a lot of folks with leaks feel this same way..right about now.
TPony is offline
Old 02-10-2007, 08:28 PM
  #37
Vicstang
Vicstang's Avatar
My 06 GT leaks, onto the passenger side footwell. Happened the day after I bought it, in some light rain. Most people don't think to feel down there and check for moisture after driving in the rain, so there may be many more affected owners that are unaware of this issue, and who so far have not reported any leaking.
So far, I've sealed the rubber boot around the wiring harness, and antenna grommet. You can see these two items with the passenger side wheelwell cover removed.
There are many possible water entry points. I hope the pending Ford TSB on the issue addresses all of them.
Vicstang is offline
Old 02-10-2007, 10:20 PM
  #38
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
It never sees rain or snow and very rarely water as it never gets dirty...hence the "I don't know" on the poll for me!
mygt500 is offline
Old 02-12-2007, 03:45 AM
  #39
HypromanGT
HypromanGT's Avatar
Still wet after 5 or 6 trips to the dealership (I lost count). New carpeting will be installed Friday. Hopefully my vote will move to the "yes, but been fixed" category, but for now it stays at a resounding "YES"[:@]
HypromanGT is offline
Old 02-12-2007, 06:53 PM
  #40
jmk3
jmk3's Avatar
My 06 vert doesn't leak, I've had the kick panel off to get to fuse panel & its dry. The Verts have a steeper rake on the windshield than the coupes so the pillar & such is not the same.
jmk3 is offline
Quick Reply: Does your 2005-2007 Mustang have a water leak?
