Fuel additives
RE: Fuel additives
The only Additives i would run would be Chevrons Techron or the Redline Brand other than that forget use a Top Tier fuel and you have no need for additives.
http://www.toptiergas.com/index.html
Richard
Richard
RE: Fuel additives
Additives will clog and plug up your injectors. I did this one time and the mechanic thatdynoed my car said it was a waste of $15 for the octane boost I added. It also showed ZERO results on the Dyno from the previous weeks run.If you have upgraded them like me the last thing you want is to be out $300 to replace them.
RE: Fuel additives
I've used X-1R before and it helped with deonation but it also can built up gunk in your fuel system. I had to have mine cleaned out. Now I heard the X1-R fuel cleaner is the same thing but with no octane boost. It has a liquid nitrous in it.
mrappe
09-26-2015 10:16 AM
