Painting the front spoiler
OK. I'm considering a CDC Aggressive front spoiler. I can get it painted or not. My plan was to go flat black. With that in mind, does it make any sense to pay the extra money to have it painted first, or can I just do the ole' spray can thing and put on 3 or 4 coats? I can see if I wanted to match a body color, but flat balc is flat black isn't it? Anyone do this?
Thanks.
Thanks.
RE: Painting the front spoiler
The agreesive chin spoiler is black plastic, as Nonstopred pointed out, so it will come flat black. As far as the painting option is concerned, I'm not sure if you can specify a color or if that means the spoiler will come painted black. If the bumper comes painted black you will have a shine to the finish, but it's still going to be black. Nothing a little Armor All can't take care of. [align=left] [/align]
I guess my confusiton comes from this listing then. maybe this is an older version? (Comes in tan)
http://cgi.ebay.com/ebaymotors/2005-...spagenameZWDVW
ITEM DESCRIPTION: BRAND NEW CDC Aggressive Front Chin Spoiler for 2005 2006 2007 Mustang GT! Classic Design Concepts created this aggresive looking front spoiler that retains the styling integrity of the car. Made of durable high-density urethane, so it won't explode on the local speed bumps. As with all body parts, preparation is needed to get the proper fit and finish. Please TEST FIT before any preparation or painting! The chin spoiler comes in a unfinishedtan color and needs to be painted to match your mustang. This front chin spoiler mounts under your front bumper cover. You will have to screw the spoiler to your lower front facia. It Includes easy instructions to assist you in the installation process. It is easy to mount by drilling and using push pins provided in the installation kit. There is no cutting required. Intallation is easy and the spoiler comes with all hardware and instruction. This item will come with the complete HARDWARE KIT. NO RESERVE!!! (DA75)
My daughter painted her rear spoiler flat black more than a year ago and still looks good. Wal-mart, primer, sand paper, paint, $4.00
The worst thing that could happen, You paint it over again. SO.
[IMG]local://upfiles/58274/AD53CF9B1CDB4232B2AC263C4215AA75.jpg[/IMG]
I see your dilemma here. The spoiler he has must be the "raw" version sold by CDC. This probably comes primed only and is ready for paint. I'll bet it's primed. Either way, you can paint it yourself, as ZZmustang advised. Flat black from a body shop and flat black done by yourself will probably produce the same result. It's all in the prep work.
I was thinking....Do you think its possible to remove and paint the lower lip on the gt bumper matte black? That seems like a cool thing to do. I may want to do that.
here is how they come also. you can buy them raw so you can paint or buy them black textured and ready to bolt on.
http://cgi.ebay.com/ebaymotors/2005-...QQcmdZViewItem
ORIGINAL: nonstopred
The reason an entire panel receives clear coat is to avoid leaving that edge. By the time everything is all said and done, you could easily spend $4-500 at your local shop. Unless your inclined to paint it yourself. I would highly recommend you go with the chin spoiler and have it painted professionally. Your idea sounds good, but probably won't produce the results you're looking for. My two cents.
To me the fit of the Agressive CS, particularly on the upper opening is ok at best. I don't see how flat black wouldlook good there. With the agressive I would only do it with a "seamless install" which CDC does not talk about. I have done it and the lower section needs a styrofoam plug support or warping is almost sure to occur (have seen several; incl mine before remedied) I have posted info and pics on proper Agressive CDC install. (You do cut away a section of the bumper cover).
Unless you are into fabrication and the like I highly recommend the Classic. get it in flat black if you want.
As your eye dr. says: "better 1 ....better 2?"
seamless install:
[IMG]local://upfiles/24316/5A18470026454A739B699FBF34BCC94A.jpg[/IMG]
CDC instructions install:
[IMG]local://upfiles/24316/2A20648842724FD5B3C4ADACE0352EBB.jpg[/IMG]
seamless install:
