Matching Caliper Paint - Updated with pics
RE: Matching Caliper Paint
I didn't get the paint until Monday so I was just able to paint the calipers today.
The paint is a good match. Since it's a metallic, I used the Preval sprayer that the G2 people used to paint the Redfire and Legend Lime examples on their site. I figured that trying to brush on the metallic would look like crap. It took a little extra prep time but I think it was well worth it. The sprayer works pretty well and I got it from Blick Art:
http://www.dickblick.com/zz250/03/
I put on three coats with paint to spare but did go through one sprayer/aerosol can. Good thing I bought a couple extra.
I should be able to post pictures before the weekend is done.
- Jason
- Jason
did you leave the calipers on when you sprayed? Did you take pictures of the prepped calipers 'pre painting'? Im just wondering how you decided to mask it off. I got my kit in yesterday and I was going to paint htis weekend but Ill wait and order the spray if its worth it. Any tips would be appreciated.
I really want to see how the Vista Blue looks. I was really thinking about going to Baer front brakes and calipers but they are a lot of $$$. Painting would be much cheaper, then I could just change the rotors.
I left the caliper itself still attached to the brake line but hung the brackets form the garage ceiling. I masked the car off around each wheel well.
I was able to hold up the front calipers byusing a piece of wire, one end through one ofthe caliperbolt holes and the other end wrapped around the spring.I had to hold up the rear calipers by hand for each coatby a piece of wire attached through one of the bolt holes - there's no where to tie it up to. In between coats I let it hangbut wrapped the wire around the lower control arm so it wouldn't touch anything.
Masking was minimal - I tried to cover the brake piston as best I could and I masked off the bleeder valve as well as the emergency brake (rear). The Preval sprayer doesn't work like a regular spray gun or a rattle can, the spray only goes about 5 inches at most. No big cloud of spray so it was easy to only paint what I wanted to paint. On the front I really couldn't mask off the pistons so I was just very careful.
Unfortunately, I didn't take any pictures before painting. Sorry!
Jason0279, did you have a chance to take some pics of the newly painted calipers? Im prob going to start mine this week. I ordered the sprayers but am kind of nervous with removing them to spray paint. I may just brush the paint on. (I have limited mechanical experiance)
Sorry for not getting to it yesterday. It was raining on and off and I didn't want to take pictures while it was dirty! I'll take some and posttonight regardless of the dirt situation.
- Jason
- Jason
Okay, pardon the crappy pics. It's raining again so I had to take them in the garage. I'll get better ones as soon as the sun comes back again but I think you can see the color pretty well.
- Jason
- Jason
that looks like it came out REALLY well... I really would like to remove the calipers and spray them, but that makes me really nervous... Do you think it would come out OK by brushing on the paint?
