Sponsored by:
Sponsored by:
Rapid ticking at WOT
Old 08-07-2007, 06:22 PM
richmod
richmod's Avatar
Default Rapid ticking at WOT
When I stomp on it, I hear a rapid ticking sound which seems to be coming from behind the radio area or in front of the shifter. I don't think it's detonation (pinging) because I've been dealing with that lately due to custom tune problems, and it doesn't sound like that. (I'm back to stock now, so no pinging). This sounds more like a tazer gun or sewing machine. It's only at WOT - any speed. I put the car in neutral at a stop an revved it above redline, and I do not hear the ticking. Any thoughts?
richmod is offline
Old 08-07-2007, 06:25 PM
hammeron
hammeron's Avatar
Default RE: Rapid ticking at WOT
i'm gonna have to go with an exhaust leak
hammeron is offline
Old 08-07-2007, 07:05 PM
richmod
richmod's Avatar
ORIGINAL: hammeron
Would there be other symptoms?
richmod is offline
Old 08-07-2007, 07:16 PM
pxdig
pxdig's Avatar
Please excuse the ignorance, but what is "WOT"?[sm=dontgetit.gif]
pxdig is offline
Old 08-07-2007, 07:18 PM
JRT1
JRT1's Avatar
[sm=gears.gif]Wide Open Throttle.
JRT1 is offline
richmod
richmod's Avatar
Wide Open Throttle.
richmod is offline
Old 08-07-2007, 07:47 PM
hammeron
hammeron's Avatar
well, i think the ticking sound might vary with
rpm's, if it is indeed a leak of some sort....
ORIGINAL: richmod
ORIGINAL: hammeron
hammeron is offline
Old 08-07-2007, 10:24 PM
ohnoesaz
ohnoesaz's Avatar
I have a tinny-clang-clang sound at WOT. Very noticeable. Definately seem to be exhaust banging on something. Possibly tranny clanging against something. Who knows. Ill take it.
ohnoesaz is offline
Old 08-07-2007, 10:33 PM
stangdude81
stangdude81's Avatar
is it the injector noise these things are noted for? I also saw a TSB about excessive noise like that being a loose lash adjuster or something like that.
stangdude81 is offline
Old 08-07-2007, 10:51 PM
white07
white07's Avatar
ORIGINAL: stangdude81
I dont know about the injectors but I know on my buddys cobra you can hear his injectors. 60 or 62 lb/hr
white07 is offline
Quick Reply: Rapid ticking at WOT
