Sponsored by:
Sponsored by:
stupid metal rattling noise at 3k rpm! EDIT: SOLUTION FOUND 9/7/07
Old 08-27-2007, 10:22 PM
LesteR723
LesteR723's Avatar
Default RE: stupid metal rattling noise at 3k rpm!
everyone has rattle problems with the 05+ mustang. just turn your music up. Its a mustang, its not gonna be perfect
LesteR723 is offline
Old 08-28-2007, 07:52 AM
imyy4u
imyy4u's Avatar
ORIGINAL: LesteR723
Yes I understand every mustang has certain rattles, but this is not a "normal" rattle. This is a metallic rattle, almost a grinding, that does NOT sound good. I do not want to wait until the warranty is up and then see I have permanent damage. I paid good money for this car, there is NO reason I should settle for or deal with such a loud, annoying, rattle that people outside the car can hear when I accelerate and think, "wow, what a piece of crap, that idiot can't even afford to fix his new car" etc. Frankly, it's embarrassing.
imyy4u is offline
Old 08-28-2007, 07:54 AM
imyy4u
imyy4u's Avatar
please keep me updated!!!
ORIGINAL: mikeei
Happens on my 05', had it to the dealer several times already, Ijustbought the car 3 months ago. Its not the heat shields and they have replaced the cats (warranty is a wonderful thing), I'll keep you posted, its going backin tomorrow. I'm pretty sure its not there once the car is warmed up. The bummer is I'm waiting on my upgrades till I get this sorted out.
imyy4u is offline
Old 08-28-2007, 08:01 AM
ErcWrestlr
ErcWrestlr's Avatar
I have the same problem. I believe it is in the mufflers. Could be the clamp. I took my aftermarket ones off and put the stockers back on and it was gone. So it is either something internally in the muffler or the clamp because the clamps tighten up way before the pipes are ever tightly clamped on. But my car has the exact same symptoms that you described above wheneever I have my aftermarket mufflers on. Hope that helps.
ErcWrestlr is offline
Old 08-28-2007, 08:36 AM
howarmat
s197 Junkie
howarmat's Avatar
ORIGINAL: ErcWrestlr
Nope cant be cause i have stingers and different clamps altogether. Sorry to burst your bubble.
howarmat is offline
Old 08-28-2007, 09:11 AM
UberHax0r
UberHax0r's Avatar
i've got this same noise. only when the engine is cold. once it warms up the noise goes away. it won't make the noise if i slowly accelerate, but if i even moderately accelerate it makes the rattle noise. first thought was a heatshield but those all seem tight.
UberHax0r is offline
Old 08-28-2007, 11:02 AM
ErcWrestlr
ErcWrestlr's Avatar
ORIGINAL: howarmat
Then I'm not really sure. I know I hear the noise at 3k rpm's on a cold start for about 2 minutes of initial driving. I assumed it was the mufflers.
Old 08-28-2007, 11:13 AM
1sloGT
1sloGT's Avatar
i had a rattle at around 1500-2000 rpms. prob a totally different sound from urs, but it came from a broken or loose "trans cross brace". Maybe that would help. good luck
1sloGT is offline
Old 09-07-2007, 07:59 AM
imyy4u
imyy4u's Avatar
Default Solution found!!!!
So, I FINALLY got the problem fixed! My normal Ford dealership was closed, so I had to take it to Woodfield Ford in Schaumburg, IL. Luckily, they had seen the problem before - and they're trying to get Ford to issue a TSB about this as it is common. So, here is the solution - and if anyone else has a problem, tell them to call Woodfield Ford in IL - 847 882 5031 - they've fixed the problem before, and did it again with me!
EDIT: the problem was the spacer plate between engine and transmission contacting the back of the engine - print the following out and give it to your dealer if need be!
[IMG]local://upfiles/44457/50CF3B92AD2F47B29EA2C9419A316316.jpg[/IMG]
imyy4u is offline
Old 09-07-2007, 08:02 AM
imyy4u
imyy4u's Avatar
ORIGINAL: howarmat
read my tech report below - it's probably the spacer between engine and trans, like it has been for so many of us already...
imyy4u is offline
Quick Reply: stupid metal rattling noise at 3k rpm! EDIT: SOLUTION FOUND 9/7/07
