stupid metal rattling noise at 3k rpm! EDIT: SOLUTION FOUND 9/7/07
#42
RE: Solution found!!!!
ORIGINAL: imyy4u
MTAS - are those the pictures of the spacer plate that's been rattling?
#43
ORIGINAL: richmod
This may explain the pinging issues I thought I was having with my tunes. Can anyone post a picture or drawing that's not quite so zoomed in as the ones above? Also, MTAS, was it difficult to get to those bolts with a socket? What did you use?
#48
ORIGINAL: MTAS
10mm x 1.5mm thread, 3/4" long - got 'em at Lowes
ORIGINAL: richmod
What size bolts did you put in?
ORIGINAL: MTAS
My car didn't come with the 2 bolts...
#49
Any specific torque specs for those bolts? I've got the same problem and looks like I'll have to try that spacer trick. Glad someone's found a decent fix along the way, this issue's been driving me crazy!
#50
ORIGINAL: howarmat
yes this can be thought of pinging, but since it only happens @ 3k you know its not....that should only happen @ close to WOT
is this the same issue everyone else has? or mufflers -
also started after i had my slp axle backs installed last year
