Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
- Ford Mustang V6 2005-2014: Interior Modifications
Step by step instructions for do-it-yourself repairs.
DIY THROTTLE RESPONSE MOD (MUST SEE!)
#411
RE: DIY THROTTLE RESPONSE MOD (MUST SEE!)
ORIGINAL: tube
WOW!
I just drove to work.
It's so perfect, so crisp, just like a cable connection. Zero dead space.
I figured out that by doing this, I am also causing the ECU to recalibrate itself. This recailbration, along with the adjustment of the brushes gives for a VERY sensitive throttle.
If I tap the gas pedal with my toe, moving it maybe 1/16", the engine will rev about 50 to 100 rpm. It's extremely sensitive now.
This makes driving a lot easier, as starting off, I can use my toe to modulate the gas pedal while letting the clutch out, while before I was forced to use my entire foot to move the pedal, which made for unsmooth starts.
I can also now heel-toe and double clutch easier, as the throttle doesn't have that huge DEAD space in it now.
If someone wants, I can take a video of me touching the gas pedal very lightly and you can see how sensitive it is now.
Heres a drawing of how to bend the brushes. B is before, A is after.
WOW!
#413
Well 21 pages later and finally got through the whole post...Tube if this doesnt work, you owe me an hour and a half of my life back... Can't wait to try it when i get my car back.
#417
I looked at my pedal assy today mine is a rev 4.0 and i noticed that the cover's screw holes are elongatedwhich allows forminer adjustment of dead space with out bending anything.
[IMG]local://upfiles/56017/D97C7DF2AF09479984CDA2AF7C73C038.jpg[/IMG]
[IMG]local://upfiles/56017/66C792204FA34F3ABD720EEF9BE74437.jpg[/IMG]
my camera isn't working so i borrowed tubes pics for referencehope he doesn't get mad
#418
ORIGINAL: howarmat
The tape is much easier to fix than broken wires
ORIGINAL: JasonIsAGeek
I'm going to try the stickytape solution. Alot easier to do and easy to remove if you don't like how it feels afterwards. The only thing I would worry about is the tape becoming too compressed over time and not working as well.
edit: I forget me manners - good job Tube. your post makes the forum worthwhile.
#419
ORIGINAL: tungstenstang
Ok i see, i shouldnt have messed with it cause i didnt see any dead space on the tracks, just wanted that extra boost so bad that i could help my-self.
If it wasn't broke, why fix it? Mine doesn't have any slack, but if it did, I would have done this.
