BMR Lower Control Arm (LCA) and Relocation Bracket Installation (w/pics)
#21
RE: BMR Lower Control Arm (LCA) and Relocation Bracket Installation (w/pics)
ORIGINAL: slvrstang2007
Dumbquestion but whats a NVH and is it safe to keep off?
#23
ORIGINAL: JRT1
I am curious about something.
When you installed the relocation brackets wouldn't that make the length where the LCA fit longer?
So how would you get the new LCA to fight right?
I have adjustabled LCAs to install, so if I make them the same length as the orginals how do you fight them in place?
The NVH noise blocks that you removed, how do you know that is what they are for?
I haven't looks to see if my car has them, I am planning on doing some of this work this weekend and I am wondering about any adverse effects from removing them.
The factory length LCA's will work on either relo-bracket hole. I know it seems like it shouldn't, but it does.
Your adjustable LCA's can be used to adjust the pinion angle.
I have no idea why his 06 (and not mine or any other 06/07 I've seen) had those big heavy blocksbolted to the axle. Do they have a purpose? I'm sure they do. Can the car function without them? He took them off and it runs fine. I don't have them, and mine runs fine.
My best guess is that they were placed there for NVH (Noise Vibration Harshness). This is/was part of Ford's project to get rid of NVH in the powertrain and drivetrain based on customer feedback. The 2-piece driveshaftwas designed because of this project.
But the question why some 06's came with and without those axle blocks are a mystery to me (and probably Ford [8D]).
#24
ORIGINAL: jwgroovin
Quick question: where did you find guidance on using the upper or lower hole in the LCA relocation bracket? You state "Note on which hole to use; If at stock ride height or up to an inch drop (like the Steeda Ultralites), use the TOP hole. If you have more of an aggressive drop, you may want to consider using the LOWER hole. " I have the Steeda springs with 1" drop, but used the lower hole of the LCA. What's the downside, if any?
The statement I made is just from what I've gathered here and there. A quick call to BMR techshould answer any questions you may have.
#26
ORIGINAL: alloutt
why do you have to remove the panhard bar bolt?
#28
ORIGINAL: Ford_Dude
It looks like the Panhard bolt is used for the reloc bracket
ORIGINAL: alloutt
#29
Ok I'm going to be installing my LCA's today so I was going over what I had to do. First step says
With the car on level ground, mark the rear shock relative to the protective outer sleeve.
How do you get around the tire to make this mark? Am I missing something simple.
#30
Is that step really necessary (especially for non-adjustable control arms)? After all, they swivel and change angles at the bushings when driving anyway.
I didn't do it and it wasn't in the BMR instructions: http://www.bmrfabrication.com/INSTALL/TCA019_22_27.pdf
