Sponsored by:
Sponsored by:
Mustang 07 Windows Doors, How do you trick?
Old 11-13-2007, 08:16 PM
mav2k
mav2k's Avatar
Default Mustang 07 Windows Doors, How do you trick?
I will to install windows tint in my stang, then I have an issue with the automatic roll up and roll down, how do you trick the door once it is opened for roll up the windows? Is it safe try with the latch?
mav2k is offline
Old 11-13-2007, 08:18 PM
PROMETHEUS PRIME
PROMETHEUS PRIME's Avatar
Default RE: Mustang 07 Windows Doors, How do you trick?
Just latch the door when it's open. Just don't close the door while it's like this.
PROMETHEUS PRIME is offline
Old 11-13-2007, 08:40 PM
mav2k
mav2k's Avatar
Thanks
For unlached May I use a screw driver in the latch and use the handle?
mav2k is offline
Old 11-13-2007, 08:44 PM
Stoenr
Stoenr's Avatar
yeah, just push a screwdriver to close the latch, the window will go up.
to undo, pull on the drivers door handle, stick the screwdriver in and open the latch.
I do this when cleaning the windows sometimes.
Stoenr is offline
Old 11-13-2007, 08:45 PM
PROMETHEUS PRIME
Yeah. Use screw driver for both. To unlatch stick it in and pull while pulling the handle.
Old 11-13-2007, 08:47 PM
Ortoch
Ortoch's Avatar
i just installed my tint with the door closed from the inside and you wont even have to bother with the latch
Ortoch is offline
Old 11-14-2007, 07:14 AM
tjs2906
tjs2906's Avatar
Don't you take the door panels off to get the tint below the scrubber bar? I haven't had mine done yet,but the guy that does it takes the door panels off.
tjs2906 is offline
Old 11-14-2007, 10:27 AM
ndnboy
ndnboy's Avatar
ORIGINAL: tjs2906
my tint gal loosen the panel to remove the trim board, then installed the moleskin, gotta have the moleskin to prevent scratch issues some have talked about
ndnboy is offline
Old 11-14-2007, 12:58 PM
tjs2906
tjs2906's Avatar
I had an 06 GT and traded it in for an 08,the material where the moleskin goesis different on the 08. Has anyone noticed this and does it still scratch the tinting
tjs2906 is offline
Old 02-24-2008, 07:52 PM
RoushGT05
RoushGT05's Avatar
Where can i get moleskin or felt of some sort?
RoushGT05 is offline
Quick Reply: Mustang 07 Windows Doors, How do you trick?
