2nd to 3rd Gear Grind Buzz, 3x Today WTF?!
#41
I am yet another unlucky one. 08 GT, have the 2nd to 3rd grind when cold. I had it into the dealer In May/June and they replicated the problems and replaced the synchros. Just last week it started acting up again. And I also get the grind after starting it up in neutral and going straight to third. So I guess it'll be going back to the dealer, I hope they just replace the whole transmission as this is very annoying.
#42
The entire transmission replacement seems to be the only "permanent" fix. Mine does it but I just go to neutral before 3rd or 2nd to 4th when the car is cold (which isn't very...here in San Diego) and by then the next time I do a 2nd-3rd shift I get no grind. I'll eventually take it in.
#43
So my buddy in his s2000 has a similar problem with tranny grinding when attempting to shift anywhere after 8K rpm (our motors would be toast by then lol).
Anyway, some guys on another forum I regularly use recommended redline oil for his tranny.
http://www.redlineoil.com/products_g...bCategoryID=16
anyone ever run it or has anyone ever heard of it?
it's relatively cheap and supposedly helps bunches
#45
I think everyone agrees to that, but that's not an excuse. I've had manual transmission cars before, and I've had gears grind occasionally, but that was due to operator error, this is not, it is "materials and workmanship" or "poor engineering". This is annoying as hell because to someone on the street it looks like those of us with this problem don't know how to drive a stick.
#46
I'm having the same issue with my 08 Bullitt. Only owned it for 2 months and only drive it about 20 miles a day, this is really disappointing to find this out when the car is still brand new. I tried a similar approach to jahudso2 which was slam it into 3rd, he seems to be the only one who hasn't had the problem reoccur since. I'll see if that ends up working.
#47
#49
I'm a little late to this thread. I got my 08 'vert this past summer. 'vert's don't always sell well up here in Alaska. Needless to say, we have cold mornings even in my garage. I'm having the same problem. It started at 1800 mi. Could you guys post the progress on your grind issues. My dealer said if I just live with it, it'll likely go away. They changed my fluid to synthetic. I want to install my Steeda Tri-ax in the spring (when I start driving it again) but I don't want them to blame the shifter.
