Sponsored by:
Sponsored by:
Someone with indash 2din nav... please help
Old 03-25-2008, 04:41 PM
GuitarGuyBMG
GuitarGuyBMG's Avatar
Default Someone with indash 2din nav... please help
Hey all. I am about to install my AVIC-Z2. It should be here today but I need to know what else I will need. Do i Need a mounting bracket and wiring harness, and if so, do I need the ones from the 2004+ F150/Lincolns that Crutchfield sells?
GuitarGuyBMG is offline
Old 03-25-2008, 06:55 PM
goodwrench78
goodwrench78's Avatar
Default RE: Someone with indash 2din nav... please help
2004+ F150/Lincolns that Crutchfield sells and the wiring harness, what factory radio do you have???
goodwrench78 is offline
Old 03-25-2008, 07:01 PM
DeStonn
DeStonn's Avatar
avic411.com is a forum where the give good advice. alot of the guys here used it when installing there kits.
DeStonn is offline
Old 03-25-2008, 07:13 PM
Boozshey
Boozshey's Avatar
Yes, you need a bracket and also a wire harness. I got mine from Best Buy and Circuit City cause I didn't want to wait for crutchfield.
Boozshey is offline
Old 03-25-2008, 08:50 PM
dmhines
dmhines's Avatar
I have a Spare Harness and Metra Install Kit .... I ended up with 2 when I installed my Avic D3 .... PM me for price if interested ... Luckily you have a 2006 car so you won't need an antenna adapter.
dmhines is offline
Old 03-25-2008, 11:35 PM
User 113021
User 113021's Avatar
ORIGINAL: dmhines
2007+ need an adapter for the antenna?
User 113021 is offline
Old 03-25-2008, 11:48 PM
ndgoalie35
ndgoalie35's Avatar
ORIGINAL: JaysFreaky
ORIGINAL: dmhines
Yes you do.
Metra part number 40-CR10
ndgoalie35 is offline
Old 03-26-2008, 12:49 AM
Deleted User
I ♥ Acer
Deleted User's Avatar
Default [Deleted]
[Deleted by Admins]
Deleted User is offline
Old 03-26-2008, 11:22 AM
mAnYsTyLeS
mAnYsTyLeS's Avatar
Don't forget a voltage regulator so you don't get a popping noise every time you turn on your car...
mAnYsTyLeS is offline
Old 03-26-2008, 11:31 AM
BigFloppy
BigFloppy's Avatar
Just take your time, it'll be worth it!
Decide if you're going to go full stealth (hiding your NAV antenna under dash / rear compartment)
Are you getting Sirius or Xm to go with it cause it would be easier to install all at once rather than having to take everything out to install those as well
Personally, I've got BOTH my XM and Sirius receiver boxes behind the rear-seat, the Blue-Tooth adapter is hidden beneath the center colsole (at the side of the cup-holders)
You'll definitely enjoy the Z2!
OH yeah, don;t forget to do the "bypass" as listed here.... http://www.sminntech.com/z1flash.html#newbypass
BigFloppy is offline
Quick Reply: Someone with indash 2din nav... please help
