Successful Spark Plug Change Tips
#21
also, be careful when retorquing the coil bolts. do not overtighten, i broke two them. if you do, don't freak out, you can get replacements at your local Lowe's. If i remember correctly the thread is 5x0.8 MM, length of 25.
The torque spec when installing the coil on plug is 53 in. lbs. Thats inch pounds not foot pounds.
