Throttle Response Fix?
Has anyone heard about this or done this to their car?
http://autobglo.com/2007/11/14/diy-f...-modification/
RE: Throttle Response Fix?
Here is the post:
Anyone ever notice that really anoying 1/2" or so of dead space in the gas pedal before the engine actually begins to rev?
My last car was a Subaru WRX with a cable throttle, I LOVED it, so responsive, so crisp.
Then I get my Mustang. The gas pedal is unresponsive, has load of dead space, and is a drivers nightmare.
Everyone always claims a tune helps their throttle response, so I purchased a Brenspeed C&L intake + SCT flasher combo. Unfortunately, 9 days after ordering it, no tracking # or item...
So today I'm at work thinking how I can mechanically remove that "dead space" in the gas pedal.
In my head, I picture the gas pedal module as being a carbon potentiometer, with a brush that is connected to the gas pedal, and moves, changing the resistance of the potentiometer, and thusly telling the ECU to open the throttle body.
Thinking some more, I decide to get my hands dirty.
I go in my footwell and look at my gas pedal. Simple enough, a black box with a plastic pedal coming out of it, three 10mm nuts, and 5 TORX screws holding a cover on the side, with an electrical connector and harness plugged into it.
I remove the three 10mm nuts, unclip the harness, and remove the entire pedal assembly.
Holding it my hand, I look at the cover, and take my T15 TORX driver and remove the cover. I pop the cover off, and VOILA to my assumption, a small circuit board, with a wedge shaped carbon film set of tracks, I think there are 6 to be exact.
I look at the inside of the gas pedal, and I see 6 little metal tabs, with about ten very fine metal wires, spot welded to the metal tabs, and bent up in a _/ shape to make contact with the carbon film on the circuit board.
I can clearly see a shiny track in the carbon on the circuit board where the metal brushes were rubbing against.
To my amazement, the track was starting about 2mm before the brush actually even TOUCHED the sensitive carbon part!!!
I take a pair of fine jewlers pliers, and bend each metal brush and tab just a few millimeters so that they will make perfect contact right on the edge of the carbon film.
I screw the cover back on, screw the gas pedal back onto the firewall and plug in the harness.
Start the engine, wait for the idle to drop. Perfect, idling around 700. I tap the gas pedal (with the tip of my TOE!)
and......
OH MY GOSH THE THROTTLE IS SO RESPONSIVE.
THE DEADSPACE IS GONE! ITS PERFECT!
It's amazing how such a small modification makes a HUGE difference in driveability and response.
If anyone wants pictures on how to do this, let me know.
Please digg my story!
http://digg.com/motorsport/Improving...chanical_Means
Step 1:
Remove Three 10mm nuts holding gas pedal to firewall:
Step 2:
Slide back red lock tab on connector:
Step 3:
Use flat head screw driver to press tab down inside of connector, and pull connector away from gas pedal assembly:
Step 4:
Take pedal assembly over to your workbench. Remove five TORX T-15 screws on electrical cover.
Step 5:
Remove electronic cover: Notice how the circuit board says REV 1.0? That means they haven't revised this gas pedal assembly since they first used it back in 2005!!! (My car is a 2008!)
Notice the circuit board with the wedge shaped carbon tracks. Notice the shiny marks on the tracks. See how they start slightly before the end of the gold track? That is your deadspace! Any movement before the very edge of the gold track will not be registered by the ECU!!!
THE ONLY WAY to fix this is mechanical adjustment. NO amount of tuning can remove this deadspace, it's simply impossbile!
Step 6:
Look at the pedal assembly. Notice the metal tabs and fine wire brushes? These are what we want to modify.
Very carefully, bend the brushes up so that they don't have such a steep angular bend in their tips. I have already done this in these photos, so it's not apparent how sharp the bend in the wires were prior to me modifying them. They are like this _/ and you want them to be straighter so that they move closer to the edge of the brass/carbon track.
Using some fine pliers, carefully bend the tips of the wires. These are VERY fine wires, be very careful.
Now bend the entire metal tabs up very slightly to compensate for the change in angle at the tips of the wires.
More pictures of the wires:
Another shot of the circuit board:
Notice that by bending the wires, we are moving them closer to the edge of the carbon/gold seam. This removes the dead space.
Step 7:
Put the cover back onto the pedal assembly. NOTE: There is a rubber gasket that goes in the slot. MAKE SURE not to lose it, or crush it, this could cause your vehicle to accelerate uncontrolably! Screw the 5 TORX screws back in VERY CAREFULLY do not distort the cover, or you may bend the wires and cause bad ju ju.
Re-install the pedal, and enjoy your new dead space free throttle!
I am not responsible if you ruin your 50$ gas pedal assembly by breaking off the fine wires, or over bending them.
And here is the link:
https://mustangforums.com/m_3792553/...tm.htm#3792553
and......
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
The top screw mod is where you put an object(in this case a screw) in the way of the pedal to restrict ii's return. Basically, you are putting the screw in place so the pedal does not return fully to it's resting place, thus ridding yourself of the dead space.
The ACTUAL problem is that the box that has the potentiometer in it does not have a guide in place and therefore is not always assembled properly. If you open the box up and look at the electronics, you will notice that the strips are mounted to the top of the box, while the brushes are mounted to the base. Furthermore, you may notice that there is no guide to properly allign the box to the base except for some screw holes which allow a lot of play.
What you end up with is the possibility that your brushes are not properly alligned with the base thus resulting in dead space at either the top or bottom of the pedal. You wont notice the dead space at the bottom as once the brushes reach the other end of the strip yourECU has regestered WOT.
So you can fix this by either adjusting the brushes directly, adding a screw, or trying to realign the box with the base.
I did the brush method on my 4.0. I have not yet made this mod to my GT but have plans to do so in the near future. I may try to realign the box instead of messing with the brushes or adding a screw.
I did the wire bending thing, and it worked, but those wires are so microscopic that it's very easy to mangle them.
A better way to accomplish the same thing is to re-drill and widen the screw holes for the cover so that you can tilt the cover in the proper direction. This is much safer than bending the wires.
ORIGINAL: thewarmachine
