Sponsored by:
Sponsored by:
Change Differential oil
Old 06-09-2008, 05:53 PM
onederful100
onederful100's Avatar
Default RE: Change Differential oil
dont forget the friction additive.
onederful100 is offline
Old 06-09-2008, 06:04 PM
FiremansGT
FiremansGT's Avatar
Most of the Synthetic gear oil brands already have the limited slip additive in them.
FiremansGT is offline
Old 06-09-2008, 06:46 PM
Lifter583
Lifter583's Avatar
Another thing, where is the best placement for a jack to individually lift the front wheels?
Lifter583 is offline
Old 06-09-2008, 06:50 PM
topbliss
topbliss's Avatar
and note that you *must* use synthetic fluid.. in fact it says so righ ton my rear with a sticker.. AND before youdrain the rear.. break the fill plug loose first. I have known people who drain the rear and then after they cannot get the fill plug loose.. then you have problems..
topbliss is offline
Old 06-09-2008, 06:52 PM
Riptide
Riptide's Avatar
I'm one of those freaks around here who doesn't know jack squat about cars and wouldn't feel comfy doing this myself without an illustrated step by step. I wonder how much the dealer would set me back for doing the labor on this.
Riptide is offline
Old 06-09-2008, 06:56 PM
Goldenpony
Goldenpony's Avatar
A lot of oils say you don't need the friction modifier, but do yourself a favor and put in 1 bottle of Ford friction modifier - you will need it. I hate using RTV to seal the cover. I found a gasket called "Lube Locker", very cool part. It's a high quality gasket with several thin beads of RTV (cured) around the whole gasket. Costs a few bucks, but it can be used over and over again. Well worth the bucks.
Goldenpony is offline
Old 06-09-2008, 07:13 PM
Meangreen1200
Meangreen1200's Avatar
ORIGINAL: Goldenpony
Use the friction modifier!
Meangreen1200 is offline
Old 06-09-2008, 09:02 PM
pat123
pat123's Avatar
Thanks for the information on the Lube Locker it sounds pretty good.
pat123 is offline
Old 06-09-2008, 09:09 PM
fosman77
fosman77's Avatar
I used the friction Modifier and Royal Purple 75W 140W, Changed this at 10000 miles and used the Ford cover with the lube locker gasket.
[IMG]local://upfiles/49854/E758C218E4AA4DF6A4B76250DBAE6308.jpg[/IMG]
[IMG]local://upfiles/49854/F97506FD5C844FADBC40703821D6FE55.jpg[/IMG]
fosman77 is offline
Old 06-09-2008, 09:25 PM
cefiro80
cefiro80's Avatar
My father just got the FRPP Diff Cover and is loving it.
cefiro80 is offline
Quick Reply: Change Differential oil
