Hood shaking on freeway
RE: Hood shaking on freeway
Mine shakes, driving 120+ regularly (Live in germany) I have never had any issues with it though, even with the center rubber adjusters all the way up. Never thought of the weatherstrip though, sounds like its worth a try. Anyone know if hood pins prevents this? I would assume so, but with the shape of the hood I wonder if its flexing in the middle instead of vibrating from the front
Mine does the same thing and I am afraid the hood gonna fly up. It only happens at around 80mph and idid adjust the rubber things but I dunno what it is. Your not alone, I am havin same problem.
just to easy you guys minds.. This is quite common on other cars too. I am on another car forum(Toyota) and some over there suffer the same issue at high speeeds. The hood bumper adjustment takes cars of the problem too.
ORIGINAL: SaddleUp
might be time for hood pins.....
My hood started shaking on the drivers side, when on the freeway.
I had the bumpers adjusted. It was fine for about a month. Then doing 80 on the freeway one night I heard the hood pop!!! Luckly the safety latch caught it!
After that I got the hood pins installed. Would of been great if the install wasn't JACKED!
Another day for part two of that story..........
Saddle, did u just get a orange GT500???
ORIGINAL: sailing220
Do you guys drop your hoods? Mine doesn't close unless I drop it from 4+ feet. No shaking here, though.
The latch was designed for a heavier hood.
Anyway, from the first week of owning the car, I put a lighter latch spring and it will close from 5 inches high.
Found the spring at LOWES, they have a great assortment. One from a F150 (97/03) does the trick too.
PS: That spring isn't gonna interfere with the good functionment of the latch mecanism.
It's out of the equation once the hood is shut.
I had the same problem going 85 on the highway!! Scared the sh*t out of me, thought it was gonna pop off cuz it was shakin like crazy!! I think its just the wind that gets under it causing it to lift!!
Our front ends being shaped like a brick doesnt help at all cuz the aerodynamics aren't very good....
Im gonna try the rubber trick like people have said they had done!!!
