Homelink (non mirror) install
Great looking setup. Too bad us vert owners can't use this location for a homelink
Here are two pics of it installed back in the car. I cant remember if I said it before or not, but the lights actually look dimmer now that the homelink is installed by looking at the pics. Dont get confused, it actually isnt. The flash of my camera makes them look that way. The brightness is actually the same as it was before the install.
Installed pics:
Andretti
Installed pics:
Andretti
Many of us vert owners use the Homelink mirror mod...
https://mustangforums.com/forum/2005...e-control.html
Any other thoughts on where to install a 20 buck home link on a convertible?
STASH IT BEHIND THE DASH OUT OF VIEW.
FLASH THE HIGH BEAMS AND THE GARAGE DOOR GOES UP OR DOWN...
Theives cant see the door opener so they cant steal/use it to
gain access to your garage.
Only you know that a flash of the high beams opens the ol garage door.
Most cars will flash to pass when the turn signal lever is pulled towards you
even with the ignition off....
Old School trick...
POWER IT WITH THE HIGH BEAM WIRE AND TAPE THE BUTTON DOWN.
Old School trick...
Old School trick...
